Results 1 to 24 of 24
    Nov 28 2015
    Montreal, QC
    to pump and/or divorce OR NOT ? ( HE option)
    So I got the reservoir and the heat exchanger, thinking about the getting the pump JABSCO ( on amazon for 250$) apparantely its the same as the APR use and I could also divorce the system.
    What,s everyone though about that ? is the pump needed ? I looked at AWE different graph, but seems like the pump can lower temp by not so much compared to a reservoir or a HE.
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Quote Originally Posted by waxxonMTL View Post
    HE and additional reservoir is all you'll most likely need. That pairing gives you the most significant improvement over stock. Adding a supplement pump is only icing on the cake.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    To be honest, since you are considering a pump upgrade, you might as well re-wire the OEM pump to trigger on at all times first, and then upgrade the pump later if the OEM unit fails.
    As for divorcing, based on my past experience, I personally think the de-pressurizing effect of it is beneficial in terms of leakage that may result in hydro-locking the engine on our fragile s/c intercoolers (the ones mounted on both sides of the s/c rotors). Many will say you loose the "benefit" of using the OEM safeguards to tell you when the coolant is running low. However, the amount of coolant I lost (and it was a lot) in the S/C loop was not enough to trigger a low coolant level light, which makes me wonder how much coolant you truly need to lose in that portion of the loop before the light does come on on the dashboard. Just some food for thought...
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Nov 28 2015
    Montreal, QC
    thanks for the input ! I will look into it, i guess i should do some more research tho.
    Apr 05 2016
    Portland, OR
    I ordered the same thing(HE and Res) and plan on divorcing the system. (I intentionally did not order the pump as I did not think it was worth it)
    If I start tracking my car more I was going to add a switch to the pump to make it run at 100% when the switch is active.
    Geoff
    Nov 28 2015
    Montreal, QC
    http://www.audizine.com/forum/showth...1#post11675126
    based on this testing, I guess for 350$cnd it just make sens to get the pump while your there anyways.. ( i mean if you decide to get it done later, you might end up paying another 1-2 labour $$ so it pay off almost instantely lol)
    Can anyone else confirm the JABESCO pump is the same as the APR/AWE ?
    http://www.go2marine.com/product/549...40-series.html
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Quote Originally Posted by Loe View Post
    Loe, have you done this? If so, do you have pics of what you did with the wiring?
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by Jflow23 View Post
    I have not, however if I could start over, its the route I would have taken first as the OEM pump flows well when the ECU triggers it to do so.
    Nov 28 2015
    Montreal, QC
    theres still a drop of approx. 6 farenheint compiled from the awe's chart ? like 24 farenheit for reservoir and HE and then an additional 6 for the pump.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    I had my front bumper off today to sort a join on my custom cooler.
    1 thig I did notice was my OE pump was working from about 60-120 seconds.
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Mar 21 2015
    Is there a way in vcds to lower the temp for it to turn on?
    Feb 05 2016
    UK
    Not that I have seen.
    If we can find out the wire that has the PWM signal we will be on target,
    If we get the PWM we can control the pump as & when we need it :)
    Jan 26 2015
    2017 XC90, a workbench
    CO
    The jabsco works great. I had to cut off the mounting bracket to get it to fit in the old pump location. And just go to your hardware store to get the pieces to connect the pump to tubing, instead of buying them for $30 each from jabsco.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Apr 10 2007
    Beaverton OR
    I divorced today...
    Weapon R Honda Ruckus coolant overflow tank
    They set me up...didn't realize the upper nipple was there after looking at the ad.
    Liars...
    Capped engine system.
    Once I saw the nipple, elected to install in a totally reversible route...no cutting or drilling of any stock parts. Not as elegant as I would have hoped.
    However, perhaps the simplicity of this mod will inspire someone to start stamping out tanks and brackets for less than $180 in a more professional looking kit.
    Hofahome DIY S/C coolant system going in soon. I have the tank, building the patience to start the install. Still recovering from the 194mm crank pulley install and subsequent belt drama.
    Jan 26 2015
    CO
    Nice man! I recommend building the bracket for the new HE before starting on the full project. As in, make it the night before. That way you can just bolt it up and start routing hoses. And make sure to check for kinks and places the hoses might rub on metal. PM if you need help. I'll probably need info in future from you for adding the 194 pulley.
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Does the pump turn on/off or run at different rates depending on the conditions? Is there a way to log what the pump is doing in VCDS? Sorry, I haven't gotten too deep into my research of the cooling system yet. Would be nice to figure out what exactly Audi is referring to as 'improved cooling' with the SQ5...and if all these great DIY setups and mods you guys are doing can be carried over for us too!
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    According to an Audi Tech and APR it runs at different percentages based on pressure and tempt. I believe APR changes this to cause it to run more, if I understood what Sean said.
    Learned a bit about the system after my tune and the tuner thought the pump was not working.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    How much does divorcing the system alter the cooling with the OEM heat exchanger? The graphs I've seen were with an exchanger, then divorced with an exchanger.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Apr 10 2007
    Beaverton OR
    Hofa, thanks for the tip...I was thinking that too. I'm going to paint them as well.
    CJW, APR's chart claims 4-5 degrees C...or ~8-10F.
    Aug 09 2015
    Sarasota, FL
    You have to also remember that the OEM unit is PWM-based unit and doesn't trigger 100% under all conditions like the upgraded pumps too. The aftermarket pumps definitely flow better though, however I do wonder if half of that drop is due to the pump operating constantly?
    Jan 26 2015
    CO
    Ya probably true. I didn't see a HUGE increase in flow (although it is noticeable) between the stock vs jabsco. I didn't even plan on upgrading the pump. The question, however, is how long can the stock unit last going full time?
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by Hofahome View Post
    exactly, i would expect the stock pump might not be up the task to run 100% of the time.
    However, just to make sure, if you upgrade the pump, will it run 100% of the time ?
    Sep 20 2006
    MD
    As Loe stated, the stock pump is only enabled when needed so it is not running 100% of the time. So, using an much more efficient heat exchanger and an additional gallon of coolant, thanks to the added reservoir, the stock pump would need to engage less often vs having the stock heat exchanger. This would lead me to believe that the stock pump would more than up to the task with the added benefit of an extended life.
    Aug 11 2015
    Alberta
    It would be useful for a tuner to chime in as well since I believe they claim they modify the pump parameters. If they could explain/elaborate, it might end up being mostly a waste to go 100% all the time.
