Results 1 to 30 of 30
    Nov 08 2008
    Los Angeles, CA
    Clutch Replacement
    Hello - I'm at 50,000 miles, and looking at replacing my Audi clutch with either another stock clutch and flywheel from Audi, or a stage 2 or stage 3 clutch and flywheel from Eurocode. Does anyone have experience with Eurocode's stage 2 or 3 kits that can comment on how they feel/drive compared to the stock clutch, and how long they may last? My car is currently stock, and I don't have any future plans to modify my S4 over the next couple of years while I still have my CPO warranty. If I do anything past that point, it would likely be to chip the car only. Thanks!
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Go with jhm. I the clutch/flywheel combo for 17k now it's it's great.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    JHM for sure!
    2021 Audi S4, P34 Intake
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Couldn't be happier with my jhm setup.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Have not heard of any Jhm issues, all have been eurocode. 15k on my JHM stage 4 no issues.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    That's pretty low mileage for a clutch replacement. What happened?
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Nov 08 2008
    Los Angeles, CA
    I have the push clutch to start issue occurring, which according to Audi means I need a new clutch. My theory is the stock clutch on these cars is quite weak, as I've never had to replace a clutch prior to 100,000 miles on any of my previous vehicles. Does anyone have experience (good or bad) with Eurocode's stage 2 or stage 3 clutch?
    Jun 30 2005
    MN
    I am a little over 50,000 miles and get major slippage from time to time while spirited driving. I am glad to hear the positive feedback on JHM. I was almost contemplating going stock due to all the posts about people having issues with aftermarket clutches.
    2013 S4 6MT | Estoril Blue | Black Silk Nappa | ADS | Sport Diff. | Carbon Inlays | B&O | Advanced Key | Supercharged Badges | AWE Exhaust / Resonated DP's | Alu Kreuz | EuroCode Intake | APR Stage 2 |
    Mar 04 2010
    95.5 Audi S6 Track car 2010 S4 with mods 2006 Audi A4 2.0T S line w/ mods, 1974 Alfa Romeo 2000 GTV
    NY/NY
    I am very happy with my JHM stage 4 clutch and flywheel. I also had to replace my original clutch at around 50,000 miles. However, I feel the APR stage 2 and track time, contributed to its early demise.
    2019 Ara Blue RS3, APR Stage 3, DSG tune, UM Haldex tune, TTE700, APR 4" turbo & throttle inlet, rear carbon tube, pendulum mount & dogbone insert, Tyrolsport Front Deadset Kit & Harness bar, Superpro LCA bushings, CSF radiator, JDY Performance oil pan, APR FMIC, Race Downpipe, catted Mid Pipes, Milltek exhaust, Wavetrac LSD F&R, KW Clubsport 4 coilovers, Neuspeed tubular sway bars and 350mm rear rotor kit, AP Racing CP9660 BBK, RSE11R 18X9 45mm offset wheels, 265/35 Michelin Pilot Cup 2 squared
    Established Member Two Rings douglasjboehme's Avatar
    Jul 22 2015
    1995 Land Rover D110 2.8TDi SW, 2016 Sepang Blue 6MT S4
    Blue Bell, PA
    So what JHM stage clutch/flywheel are people getting for stock S4s? Stage 3 seems to be the right one for anyone driving the S4 like it should be driven.
    2018 RS5 | Misano Red | All Options | AWE Touring Cat Back, BBS CH-R Nürburgring Edition Wheels
    Jan 26 2015
    CO
    Quote Originally Posted by douglasjboehme View Post
    I got stg 4 and it feels like stock with about 10% stiffer engagement. Even had a friend drive my car and he couldn't believe it wasn't the stock clutch. He had driven it prior to the clutch replacement. Only difference is it doesn't slip.
    Dec 03 2008
    2018 SQ5
    I went stage 3 with lwfw
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    i had no idea jhm was problem free thus far... I guess I sort of lumped all clutches together after the "push clutch to start car" debacle.
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    I have the JHM LWFW, JHM Stage 3 R clutch (if you want the 3R you'll have to call them and ask specifically for the product, as they don't appear to be publicly selling this clutch for the B8, yet), stainless slave line with frequency resonator delete, JHM short throw, and JHM solid linkage. Paired that with 034 tranny, rear diff, and rear diff carrier inserts and you have yourself something LOTS more fun to drive.
    It does create a bit more NVH. However, in my opinion, it's 100% worth it!
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Apr 27 2015
    canada
    ^ I appreciate the tip. Also, I enjoyed your video in your build thread very much.. <-- probably one of the better videos i've seen of the s4 recently.. i've got to get an exhaust and work on this clutch (even though it's working fine in stock form currently but your video is inspiring me).
    Jul 16 2010
    Colorado
    The push to start clutch issue was a leaking slave cylinder and the clutch pedal needed to be slightly adjusted, but stage 3 feels on par with stock. Same pedal feel, but way better grab. Make sure to add the USP braided clutch line too!
    Jul 16 2010
    Colorado
    Quote Originally Posted by Lensch09 View Post
    -DL
    Do you notice any difference with the solid linkage upgrade? Does it just reduce the side to side slop when you wiggle the knob in gear? I seem to have a weird issue with my linkage that when the car is hot it can be more difficult to shift and requires more effort than in cooler weather. Any idea on what the issue would be?
    Feb 20 2004
    Quote Originally Posted by EHesh14 View Post
    Could be the plastic wearing out if you're still on the stock part.
    If you're on the JHM part, my guess would be that it's an adjustment issue.
    -DL
    Previously:
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    As far as I know, there is no adjustment of the clutch pedal.....or master cylinder, or the slave cylinder.........
    Nov 12 2015
    Here
    Quote Originally Posted by S4'ed View Post
    Yeah, not with OEM parts. Not sure what "adjusting the clutch pedal" means... Maybe there is an aftermarket slave with an adjustable push rod out there?
    Mein ist grau
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I did the jhm shift linkage recently with ECS short shifter at the same time. It's hard to gauge what the linkage did exactly but I have zero side to side movement and it feels VERY solid going into every gear.
    Sent from my SM-G925V using Audizine mobile app
    Apr 27 2015
    canada
    -DL
    What does the "R" denote? racing? stupid questions but what is the frequency resonator delete (first time hearing that) and what does NVH stand for? I can't find any info on the 3R clutch
    Veteran Member Three Rings TappaNuKegga's Avatar
    Apr 07 2016
    PA
    Quote Originally Posted by Thurston View Post
    I spent 15 minutes yesterday trying to search for what NVH means.
    Noise, vibration, and harshness.
    Apr 27 2015
    canada
    haha man that made me laugh a bit. I have a seriously lacking knowledge about clutches and their lingo. ^
    Mar 25 2015
    Calgary
    Anyone who has a JHM setup, does the JHM clutch provide a better feel than the stock clutch or is the delay valve always going to be the culprit of a vague feeling clutch on this car??
    Jul 16 2010
    Colorado
    Quote Originally Posted by Geomatics_Tech View Post
    Oh yea I think the pedal is more firm. Not incredibly, but noticeable
    Jul 16 2010
    Colorado
    -DL
    I'm on the stock. that would make sense since the spherical ball is plastic
    Senior Member Two Rings ellwood's Avatar
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    Quote Originally Posted by ModItNow View Post
    Were you able to install the linkage without dropping the trans? It seems that the bolts for the shifter connecting rod and push rod on the passenger side wouldn't be accessible without lower the trans a few inches
    2021 M340i xDrive, 2016 Sepang SQ5, (sold) 2012 Glacier White S4 6MT - APR Stage II
    Jul 16 2010
    Colorado
    I'm wondering about this too and I'm hoping not
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by ellwood View Post
    Honestly I am not sure, I had my shop install it along with some other parts.
