The software started to flash to the car and everything seemed to go smoothly (fan kicked on etc ) ....UNTIL the software reached 100% . It stuck on step 6 of 7 at 100% and threw the following error AFTER weirdly requesting me to switch the ignition OFF then back ON:
After hitting retry serval times, nothing happened. So the only option was to hit cancel. Upon hitting cancel I was then presented with the successful burn page (step 7 of 7):
Proceeded with the instructions to switch the car off and on multiple times with a 30 second interval between them etc, and hoped that error didn't screw anything up . Also received the burn notification email.
Then I went to drive the car.... Once the car builds up boost past 11ish PSI it bangs and pops and God knows... The car violently jolts to the beat of the bangs and pops, thus making me extremely worried. As I nervously drove home I couldnt get past around half throttle without the jolting and bangs occuring. I took the following terrible videos to show what is occuring :
(Windows are closed in this video so hard to hear, issue occurs around 11psi from the p3 gauage I have installed)
Then went to reflash the tune, and the exact errors and results occurred.
Im extremely anal about my car so I'm ontop of everything , and the car is in perfect condition, with zero issues prior to the tune. The only other engine modification I have is an APR carbonio intake and a jHM test pipe with no rear mufflers also. Additionally, I ran the car through VAGcom before tuning, zero codes/faults, ran VAGcom again after the tune, displayed all the normal JHM info within the VCDS, but still no fault codes or CELs or anything :-(
I will call JHM Monday regarding this, from what people have said they should be more than helpful...but since it's the weekend, I thought I'd post this here to see if anyone has experienced this issue or has any insight on this, becuase I am completely freaking out about my baby :(
Sorry for long post and thanks in advance.
