Results 1 to 3 of 3
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    How to remove climatronic unit? - - stuck taking apart the interior :/
    Hi All,
    I'm neck deep in pulling out the entire interior (upgrading stereo system) but I'm stuck on getting the center console out. I have pdf's from Audi, but they all just say:
    Remove the Climatronic Control Module - J255- . Refer to ⇒ Heating, Ventilation and Air Conditioning; Rep. Gr. 87 ; Display and Control Head; Display and Control Head, Removing and Installing
    without any link, and I can't find anything that covers this in any of the docs. Anyone have any insight on how to remove the AC display unit/climatronic display head so I can get the center console out?
    Thanks much,
    Per
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Bit late reply, but you simply have to prim a thin metal wide tool verticaly between the AC unit and the side leather console. I used a pancake scoop :p. It did the job perfectly.
    Just slowly slide it between and carefully prim/pull the ac out on one side, then the other side.
    Good luck.
    In worst case i can take some pictures but 'monkey' job with the right tools.
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Feb 17 2004
    2013 Audi S6
    All good, thanks much! Got that tip earlier, too, and sure enough, easy as can be. I have a trim removal tool set and used the thinnest one of those.
    Right now, entire interior is removed, time to do a bit of sound deadening and running some speaker wires :) .....aaand, I thought I hit submit before, guess not: added CLD and MLV, and got the carpet back in. Long, but satisfying day :)
    Never forgotten:
    2002 S4 Stage 3 Tip
