Results 1 to 2 of 2
    Established Member Two Rings Wyd's Avatar
    Jun 29 2016
    WA
    Angry oil pump, oil windage tray
    Tore my oil pan off last night to find my pickup manifold was missing a big chunk of the plastic (which i found in the oil pan thank god). not entirely sure how this happened.
    ordering new stuff and noticed a Windage tray, does this sit between the pump and oil pan? if so mines gone. part # 079115287A
    also could anyone provide me the part number the auxiliary hexagonal drive shaft that drives the oil pump and water pump?
    im assuming the extreme amounts of play in my oil pump is causing the shaft to miss the housing and not drive either of the pumps. making sence that i have both a red oil pressure and cooling system light.
    Jul 15 2015
    Rochester NY
    If I'm looking at the right part on partscatalog.info, it's 079115120S "input shaft for oil pump". Try putting your VIN in to that website. If it works, it might avoid showing parts that don't apply (for the windage tray)
