Results 1 to 7 of 7
    Aug 19 2013
    minnesota
    Front wheel bearing triple square torque specs
    Im reading conflicting info about the 4 triple squares bolts for the front bearings, any one know? Axle bolt too
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Senior Member Three Rings GTA's Avatar
    Feb 08 2013
    2003 Audi A4 1.8TQ, 5-Spd
    Toronto, Ontario
    Grabbed this from ECS Tuning's web site. I used this when I did my RF Wheel bearing last year.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...stallation.pdf
    If this link doesn't work, just go the ECS site, search for wheel bearings for your car, and click on the Installation link found below the item description, this this case, I chose the Audi OE bearing part ES#: 261612.
    I found the Axle bolt to have one crazy torque at 140 ft-lbs + 180 degree turn. But I did it and it's never coming off, LOL!
    Feb 05 2009
    Good ole south
    Per Bentley...
    Wheel bearing bolts = 59 ft-lb plus 1/4 turn
    Axel bolt
    M14 bolt = 85 ft-lb plus 1/2 turn
    M16 bolt = 148 ft-lb plus 1/2 turn
    Jan 06 2009
    You have the M16 axle bolts. M14 is the B5.
    200Nm + 180deg.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Aug 19 2013
    minnesota
    Thanks dudes, time get out the 6 foot pipe for that extra turn. I remember when I did the clutch, I don't think I ever got that extra turn either. I'm going to get it this time.
    Nov 09 2019
    Earth
    Sorry to awaken the dead but I am having an issue getting the left bearing off the knuckle. Right side was easy peasy.
    Feb 08 2013
    Toronto, Ontario
    They can be a Beech to get out. When I did mine, it took me two days of hammering, using a slide hammer, penetrating fluid and lots of swearing - and it still wouldn't come out of the spindle/knuckle/upright.
    Ultimately, I decided to remove the whole spindle/knuckle/upright assembly and take it to the hydraulic press. Even then, it really stressed the press before it let off a loud bang when it let go. There were pieces flying everywhere as the races separated into multiple pieces. That sucker was in there!
    In the end, it was a wasted expense and effort as I thought it was that bearing making the droning sound that drove me bat-sh!t. No change in the noise after replacing the wheel bearing. It ended up being the worn tires that was making the noises. A fresh set of rubber make all the difference, LOL!
    If it's being stubborn, you may have to do what I did and take it to a shop with a press, control arms and all because of that notorious pinch bolt may give you just as bad of a headache.
    It's mind over matter. But if you don't have a mind, it really doesn't matter.
