car is a 2001 A4 1.8t AWM.
ive been using Maestro just fine for months on this ecu just fine. last week i tried to flash in a new file and it stopped at "Verifying 90-00" and threw a message for a session timeout. then it threw a message saying i need to license my ecu blah blah blah. It will also not except any softcode changes thru VAGCOM either.
so i scanned it for codes and there are two recurring codes, P0600 - serial link communication and P0688 - ECM power relay sense circuit. i have since verified that the ecm relay, and all other realys and every single fuse and ground in the vehicle are good. i have a spare stock ecu and am running that for now with stock hardware and it runs fine and does not throw any codes other than for my missing LDP, EVAP stuff, etc.
My maestro tuned ECU is behaving exactly the same on my benchflashing setup. it will not except a flash, or softcode changes, but i can still scan and clear codes. it is still throwing the P0600 and P0688 codes, but when i connect the K-line, it throws the P0600 and i different code for ECM power relay-short to plus. i opened the ECU case and there are no signs of corrosion, burning, etc on the associated pins (or anywhere else)
I am really seeking some insight as to what to do now to save the ecu, i would like to not have to buy another $500 license for another ecu.
so far all eurodyne has said is try and flash at a slower speed...didnt work.
