In the last month or so i have had such a bad luck with ABS system that sometimes it just doesn't make any sense as what the hell is going on. It all started with intermittent ABS and ESP Light solid On when driving over 75mph but never under 70mhp and this was like a year ago. Once i turned the car off then i can drive for half an hour at above 75mph and eventually these two lights would come on and stay on until the car has been turned off (strictly above 70mph)
Fast forward, a month ago things got a lot worst, there are times when ABS and ESP light come on right after the ignition without driving and they would go off as soon as the car starts moving forward, there are times they would come on while driving. There is times where there are no lights on Dashboard but the ABS would kick in whilst coming to a stop at slow speed on dry summer weather.
First thing i did was to scan for codes and VCD showed 3 codes all related to speed sensors which i ended up replacing it but the issue did not get resolved, so i took my ABS module out and send it for repairs to BBA Reman, after getting back i no longer get the ABS kicking in but the Christmas lights never went away in fact i got one more Christmas light and that is the Handbrake Light.
Now i have a combination of ABS light, ESP light Solid On whilst Handbrake Light Flashing unless handbrake is engaged, this again happens a lot of times as soon as the car is turned on, there are times when ABS and ESP come on at start up and eventually the handbrake light flashing down the road whilst driving, this things its driving me crazy.
Here is what i realized;
When ABS Light and ESP light are On - i can't access the ABS module with VCD, it says cant connect to module controller
When ABS Light and ESP light are On with Handbrake light Flashing i can access the ABS Module and showing that three of my wheel sensors are deviant
Like i said i replaced all 3 sensors plus i sent out my ABS module twice out for repairs, I'm kinda speechless as what can it actually be...
Can anyone suggest something else...
Thanks
