Results 1 to 14 of 14
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    SOS please help!!
    So I was driving home from the gym tonight and I had noticed a weird noise coming from my turbo. I didn't think it was much. But 2 minutes later, i had gotten to a stop light, and the whole car started shaking like crazy as if it was close to stalling. I pulled over and turned off the car and tried to start it up again and the same thing happened. Extremely rough idling. I had driven home and scanned it with an OBDII scanner since I have no VCDS. 7 codes came up. One of them saying turbocharger, and other were saying misfires in all 4 cylinders. (I would have provided you with the codes but my dad had cleared them thinking it would fix the issue...) I'm lost and have no clue what is going on. I'm in a desperate need for help.
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    what did the noise sound like from the turbo - can you take a video of it?
    rough idle could be many things, but you can start by checking/replacing your coil packs and spark plugs...could also be carbon buildup...how many miles on the car?
    did you get a MIL?
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    check the plugs and coil packs, whats your milage? have they been replaced?
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    same thing happened to me on wednesday.. got r8 coil packs and NGK plugs and it fixed the problem.. like they said above, check em.
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    May 16 2015
    Quote Originally Posted by kdaffy View Post
    did you get a MIL?
    Cool packs were changed not too long ago, just did carbon cleaning less than a month ago. I'm at 102k. No MIL either. The sound from the turbo sounded scratchy. It wasn't a whistle, it was a very feint scratchy whirl.
    AKA: NathanMansoor
    Feb 24 2013
    CA
    Pcv valve perhaps? Or you may have a boost leak somewhere causing to idle rough or die. Its usually one of those.
    May 16 2015
    Quote Originally Posted by Slick_B8 View Post
    I finally had some time to look at the car, and it ended up having a vacuum line popped off under the engine cap.. does that just happen on its own?
    AKA: NathanMansoor
    Feb 24 2013
    CA
    Quote Originally Posted by TurboNate View Post
    Not usually but i was pretty sure that was it. Its happened to me before lmao just make sure its clamped on good?
    Jun 26 2009
    Bremerton WA
    Not to sound too negative but with the intake cleaning being a month ago likely it wasn't clipped back into place fully. I am guessing by the symptoms it was the hose from the intake manifold to the PCV?
    VMR 710's, APR software, Eurocode HFC
    May 16 2015
    Quote Originally Posted by van462 View Post
    Yea that's the one
    AKA: NathanMansoor
    Senior Member Two Rings redeye_jedi's Avatar
    Dec 12 2015
    Sk8teboard, Audi B8 A4 Quattro stg2
    Vaccum leak
    / AUDI A3/8V Quattro / 034 Motorsports Stg1 ECU/TCU/ ST's /
    18” Split 5’s / 235/40/18 conti’s
    / AUDI B8 A4 stg2 / kw’s, sway bars, intake / 19” Black Peelers /
    / 245/35/19 Federal’s /
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Yea that's the one
    you can leave it like that and just cap off the intake port if you like...less carbon deposits on your intake valves that way...also will help avoid blowing a rear main seal when your PCV dies and you've got a tune pushing well above stock PSI...
    May 16 2015
    Quote Originally Posted by pierreb View Post
    I'm not tuned, I'm stock
    AKA: NathanMansoor
    2020 A4 allroad
    NH
    You can still blow a main seal with a PCV failure, but it's less likely.
