Results 1 to 40 of 44
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 25 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Coil upgrade?? 2.0t fsi vs rs6
    Anybody have any first hand experience on which set is the best ?? Did u even feel a difference afterwards?
    Apr 07 2011
    Home of the mighty beaver
    ive heard claims the R8 ones are "better"
    but nothing in terms of raw numbers. I have read that the regular tfsi (2.0) coils are 20% stronger than the stock ones.
    Jul 04 2012
    Woodbridge, VA
    Rs6 will give you less headache. They bolt on like stock (sealing out moisture and self grounding) while the fsi will need an extra ground wires. Rs6, if used in conjunction with the harnesses, is a true plug and play, reliable kit.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Upgrade is a very loose term. I think aesthetics and the fact that it's cheaper to replace the old system with the 2.0 coils is the main driver for people swapping.
    Apr 07 2011
    do the RS6 ones eliminate the need for the ICMs like the FSI coils?
    I have one of these shitty FSI coilpack conversions and I hate it.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by S4James View Post
    Yes, you eliminate the ICMs with the RS6 coils. They are more expensive than the 2.0 coils, but you don't need adapter plates since they bolt in like the original 2.7 ones.
    Senior Member Two Rings czsrock1990's Avatar
    Apr 20 2010
    2001.5 Stg3 B5 S4, 2001 B5 S4
    Chicopee Ma
    x2 on RS6 coil kit. Put mine on a month ago and love love love them. They bolt right on and have the ICM delete.
    Pearl White Stage 3 B5 S4
    Brilliant Black B5 S4
    2004 Dodge Ram Cummins (Sold)
    Silver B6 S4 - Milltek catback, VMR 708's, (Sold)
    Apr 07 2011
    they are wired the same i presume? I can use my existing 3->4 wire adapters?
    Jul 04 2012
    Woodbridge, VA
    Yes sir.
    The fsi and rs6 and r8 use the same connector.
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    x3 on the rs6 coil kit, they are super easy to install, seal up to the valve covers nicely....034 has a kit pretty good....idk if it was and upgrade but it will save me $$$ in the future with failing coils and icms
    2008 Ibis RS4....GETing tuned
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I dont think people realize this, but there is nothing special about them just because RS6. They were used on all sorts of cars. The FSI coils are upgraded style.
    The RS6/ATW coils aren't that bad, but I would upgrade my ATW to FSI coils.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by redline380 View Post
    This goes back to "define upgraded". Seriously, you could say the exact same thing about the fsi, what is upgraded about them? Quick change? Tendency to die quickly?
    Now going back to the reasons to "upgrade". Most people are "upgrading" to get rid of ICM fail point or just because they have a couple bad coils so just taking the opportunity. Additionally, the newer ones are cheaper so down the road you won't spend as much to replace.
    Now, when I change something in a car I want it to work the same if not better than what I replace it with. The fsi coils, while at 15 a pop, I've seen die all the time. Rates exceeding stock beru coils. Then throw in the fact that it water gets in my engine bay it will easily pass by those conversion plates or through the "quick change" area? Then to make matters worse, the FSI conversion doesn't play nicely with our cars unless you use the updated harnesses with grounds or run your own. The addition to the harnesses is already super messy and adding a ground wire on top of that is really messy.
    So, with regard to options for "upgraded" coils, the Rs6s are in fact special. They are true plug and play and leave it alone.
    Senior Member Two Rings joeSfour's Avatar
    Nov 09 2011
    South Bay, CA
    Quote Originally Posted by awd2ks4 View Post
    If you aren't having problems with your current set up, don't change it. The only reason I went to the RS6 style coils was because it was cheaper than buying new IMCs at the time. That being said, if you are going to change up the coils, I would go RS6.
    Current - 2001 B5 S4 Imola Avant
    2009 VW GTI
    Past - 2002 B5 S4 - 034 STK 5858 PT fully built 3.0L
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by vavJETTAw36 View Post
    Glad I didn't respond as you summed up my thoughts nicely. I have seen no evidence that 2.0 coils are a performance upgrade. They are just cheaper and fail more often than the stockers. As soon as you purchase a second 2.0 coil, you could have bought one of the factory coils for the same money...
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Odd I've seen the latest FSI coils to be quite reliable. But anecdotal evidence is just that right.
    I've never seen the need to run an extra ground at all... Ever. It makes ZERO difference to the coil where the GND comes from. When I make coil harnesses to convert (all kinds of) cars to FSI coils I just use one GND point (chassis) and put a jumper between the pins under the boot. Works perfectly fine.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by NOTORIOUS VR View Post
    Not sure I follow. You just stated you run a ground. Running a ground is not the same thing as running an extra ground? Rs6 coils you plug the bastards in. Maybe I misunderstood
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    They aren't plug and play, you still need to adapt the harness.
    FSI coils deliver a stronger spark as evidenced in the increased gap.
    10k on my FSI coils in my A4, no failures. And they are cheap. However, FSI coils in my A4 truly were plug and play.
    If you have problems with water getting in your engine bay, I'd be more worried about that than which coil you are using. I simply wanted to bring up the fact that everyone seems to think RS6 cols are special. They are not and were used in many models. Also, any revisions done to the car to run RS6 coils will set you up for FSI coils too. Make up your own mind.
    2000 S4- Working?
    Jan 29 2009
    Correct, no extra ground. There already is a GND point to every existing coil plug. You don't need 2 grounds like you claim.
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    I've been running FSI coils for over 2 years and haven't lost one yet. Those 2 years included a lot of driving - probably >30k miles, including a 5,000mi over 3.5 weeks cross-country trip, and multiple Southern Oregon to San Fran, LA, Portland, & Seattle trips. I've never had any issues with water in the spark well, and I use the Touareg plastic adapters.
    Yea, the RS6 coils may seal better and bolt down like stock, but I prefer the convenience of a push down coil and $15 replacements.
    Jul 04 2012
    Woodbridge, VA
    Are you referring to the existing circuit running through the factory harness? Yes, the brown wire.
    Why do you think the ecs kit uses the extra ground wire on their harnesses? Seems to me they created a product knowing full well they'd need an extra ground. Does the 034 have one? No. There's been many guys on here that have had to ground the coils better.
    Jan 29 2009
    I have no idea why someone chose to do something the way they do. But you making assumptions isn't the right way to go about it. If you trust ECS for some strange reason all the more power to you. I know people who have over 100k km on the 034 FSI kit without issues (except that they don't do good QC on their products and sent us an ICM delete cable that had wires crossed which almost made us rip out a whole motor trying to diag the misfire issue).
    Everyone has to remember that these cars are OLD... the Wiring harness on these cars has gone thought a lot of stress and heat and movement from people ripping at them. I'd sooner guess that failures are due to poor connections/wiring or even bad crimps for these plug and play kits.
    In either case, there is no problem connecting it either way. Adding more grounds doesn't give you any more reliability or spark or whatever else you might think it does, that sir is a FACT.
    Jul 04 2012
    Woodbridge, VA
    I agree with you wholeheartedly regarding our old cars and old wiring. Most of the issues are probably due to pre existing or new grounding issues. But I can only assume just like you can only assume.
    I dont have any idea and you don't have any idea why ecs chose to add a ground wire, that is true. But if I were selling I product, I would not add functionality for the hell of it. Do you seriously think ecs felt like adding wiring because they were feeling nice that day? Come on don't be hard headed. They most likely had many complaints about it and revisioned their product.
    Aug 24 2014
    Newport Beach, CA
    Ha, you people are making this choice harder for people by going back and forth countering each other. I personally find that stock coils and ICMs are more than adequate for almost all power levels, as long as they are in good shape. Plus, it's easy to find ones in great condition for cheap from people who switched to FSI/2.0/RS6 coils. However, to Notorious' point, a lot of these cars eventually will have problems with the stock wiring harnesses going to the coils and cause issues.
    On my car, some of the outer covers on those coil wiring harnesses are splitting and want to find a solution to that.
    2024 M3 Comp xDrive
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    In my four years of b5 ownership I've never had a single coil or icm fail 😂
    Jul 04 2012
    Woodbridge, VA
    So I found out from ECS that it depends on the plates being used. Since some of their kits use a powdercoated plate, the ground wire is to make up for missing contact on the valve cover. So that is the difference. So just keep that in mind when looking at plates.
    Jan 29 2009
    I'm not really assuming.. I've seen what the wiring does on cars of this age. I had issues with my personal car as well. The wiring is hard and brittle.
    I'm not thinking or assuming anything. YOU are though for whatever reason. Why someone chooses to do something one way or another is really up to them.
    What I am telling you though is that you don't need separate grounds.
    Again, makes zero sense. Who cares if the plate is grounded. It's not like the coil is grounded to the plate anyway.
    Jul 04 2012
    Woodbridge, VA
    See post above
    Apr 07 2011
    Quote Originally Posted by mikeb17 View Post
    Well now you have done it... What could possible go wrong?
    Dec 10 2013
    Borden, Ontario, Canada
    Exactly, just jinxed himself lol
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Oct 27 2012
    Lamborfeetes
    Washington
    You guys are superstitious 😂
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Look the Audi wiring diagrams where these coils are used, and how they are wired. The power ground is separate from the signal ground, and for a reason! It is not the same that how those are grounded. The coils will make radio frequency interference which can produce many kind of problems. And separating the grounds help not to get that interference to the ECU. I can't explain this very well in English, but you can search it from the internet if you don't believe me.
    And think about a bit, why Audi would do something which costs money, if the don't have a reason for it!?
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    I did the 2.0T Coil Conversion for no other reason than it being "a thing" that everyone else seems to do. Really created more trouble than it was worth with all the splicing and BS.
    Regarding the 2 grounds per coil, which I've mentioned in other posts, I ended up running one of the pins to an individual grounding point on each valve cover.
    Why? I was having @ idle misfires ONLY after installing the 2.0T Coils.
    Was the initial pairing of grounds the cause? I've no idea, but the issue went away after running individual grounds.
    Was it all worth it? I seriously fucking doubt it to be honest. Should have just bought a new stock coil.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    May 11 2013
    Nnj
    so what is a ignition upgrade for these cars? so the stock system is good for 30 + psi ?
    Dec 10 2013
    Quote Originally Posted by Mark00s4 View Post
    Stock system is proven to 700whp. I know a guy running +40PSI on his built single turbo with stock coils
    IG: 24_et
    Sold:
    RIP:
    Aug 25 2008
    Santa cruz
    I'm starting to get some misfires/studders at high load high boost on hills which makes me think it's getting blown out. New plugs gapped a .028 and it still does it sometimes. So I'm thinking new coils are in order since I've never changed them got the car at 60k and I'm at 140k now and i want to delete the icms anyway. When running rs6 coils where do I get the harnesses and icm delete? I know places that sell the icm delete wires but not the harnesses for the coils
    Sep 09 2014
    Grand Rapids, Michigan
    If you do the solder method you actually can clean a lot of the wiring harness up and cut out some of the old brittle wires. It will cost you under $200 for everything all said and done as well. Touareg adapter plates are like $6 a piece, you can buy r8 coils for $130 or so and 4 wire plugs for another $30 as well. More time to do it but it's the same effect and cheaper in the end.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by Trb1 View Post
    Time is money baby.
    Aug 25 2008
    Santa cruz
    So can I increase the gap with these rs6 coils ??
    Jan 29 2009
    That depends on how tight you had to go with your other coils.
    If your OEM coils were in good shape then you probably didn't have to gap them down much in the first place.
    That said, you can certainly try opening them within reason and see if your setup works with that.
    Aug 25 2008
    Santa cruz
    I usually run a .028 gap
