Results 1 to 3 of 3
    Aug 28 2015
    1991 Dodge D150 2001 Audi S4 Imola
    indiana
    How to find out which Maf?
    I have a 2001 audi S4, build date of 05/2000. I have a different maf housing and cant get any good part numbers off of the maf sensor. it has early style intake mani and badges. would I have hitachi or bosch? aswell looking for a new wiring harness, this is why I'm trying to find this out
    2001 Audi S4
    Stage 3+ w/ Tial 605 Turbos and Ringer Racing Stage 4 Clutch
    Established Member Two Rings Ob3R's Avatar
    Apr 29 2013
    '17 RS3/ '00 S4/
    Omaha, Ne
    Bosch if your s4 is the older style of logos.
    But if you change out your wiring harness you could possibly switch over to the much more reliable hitachi MAF. But that might require to change out the Ecu unless you have a tuner who could change the ecu from bosch to hitachi
    Sent from my Forever Check Engine Light B5 S4
    DD: '17 RS3
    Project: '00 Audi S4 6MT Imola Yellow
    Previously Owned: Too Many...
    Aug 24 2014
    Newport Beach, CA
    You can use a wiring harness from either Hitachi or Bosch cars, you would just have to wire the MAF correctly according to this. Also, you have a Bosch car. All early style cars 2000-2001 (before 01.5s) are Bosch MAF, as for swapping to Hitachi the reliability thing is overstated vs the Bosch so as long as your MAF works correctly I'd leave it as it.
    2024 M3 Comp xDrive
