Results 1 to 22 of 22
    Jun 18 2009
    Phoenix, AZ
    MMI adapter for newer Apple iPhones/iPods?
    Hey all, I've had my 2016 S4 for a few weeks and it's been an awesome car! The only thing I'm trying to figure out right now is the integration with MMI. There is an adapter in the glove box that is for the older style iPhones, I think it's called a 30 pin connector, and my iPhone 6s has the smaller lightning connector.
    Basically I need this, but a lot longer so I can keep the phone in a cup holder, but so that I can charge the phone and listen to audio at the same time - https://amzn.com/B00MPO23IQ
    The one that is in the glove box now works, I have a small adapter to go from 30 pin to lightning, but it's very short.
    Do any of you recommend a particular brand/etc that would work?
    2017 Camaro SS 1LE
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Just get a lightning extension cable. There's no oem solution for your need.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Jun 24 2008
    Encino, CA
    i got this to extend my short 30 pin to lightning
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Oct 08 2015
    Quote Originally Posted by kgb006 View Post
    Just curious, how do you direct your cable from the glove box to somewhere easier to reach? I tried a cable like this before but it made my glove box hard to close and almost broke my cable after a while.
    Current: '18 M3 ZCP
    Jun 06 2016
    Florida
    Quote Originally Posted by yjypm View Post
    I removed my glove box, cut a hole behind the MMI plug, and routed the cable over top of the glove box and through the center dash.
    Oct 08 2015
    Quote Originally Posted by Dirt View Post
    That's very interesting, how long did you spend / how hard was it?
    Current: '18 M3 ZCP
    Established Member Two Rings jpatterson's Avatar
    Mar 16 2009
    Trussville, AL
    Why don't you pair your iPhone via Bluetooth and stream music and other audio? I do that in my S5. I use a USB charger in the armrest compartment for charging the phone if necessary. I have an old iPod in the glovebox on the AMI connector. I keep my stored music there and can control it from the steering wheel or MMI knob. I do Pandora ect on the iPhone and control it from the phone.
    J. Patterson
    Alabama
    2015 S5 Prestige 6 spd manual
    2015 Q7 TDI Premium Plus (with the emissions fix)
    2001 TT 225 Quattro Coupe (some mods and track time :-) )
    2001 TT 225 Quattro Roadster ( pure stock)
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by jpatterson View Post
    I do this now, but when I plugged my phone into the MMI directly, there was a noticeable difference in sound quality. That's the main reason.
    2017 Camaro SS 1LE
    Oct 08 2015
    I don't know about the OP but I hate using Bluetooth because I have to wait a minute or two after I started my car for music / nav app to start streaming. I don't use the music app so i have to play the music manually while driving. It's kinda uncomfortable.
    Current: '18 M3 ZCP
    Jun 06 2016
    Florida
    It wasn't too bad. The glove box is held in place by roughly a dozen bolts. Once I figured out where they all were, the hardest part was trying to decide where to make the hole. I also slid the radio out in order to run the cable, which is super easy (need radio removal tools though).
    Oct 08 2015
    So where does your cable come out?
    Current: '18 M3 ZCP
    Nov 10 2014
    Apex, NC
    get the official lightning adapter from Apple .. i bought one from Amazon and it would charge it wouldn't play music, then i went with an official apple one and it worked in every audi i plugged it into.. 5 so far
    and get this one
    if you get this one it won't work with a phone case
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I have a 2010. If I plug in my phone can I still go through and play songs in Spotify let's say? Or is the screen going to be locked?
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by CELison View Post
    you can still play it.. screen won't be locked like full iphone integration where you see the icon .. i use mixcloud and sound cloud all the time with mine
    Present:
    Mar 16 2009
    Trussville, AL
    Quote Originally Posted by FWP! View Post
    Understood. I usually use an iPod classic plugged in to AMI unless I'm streaming Pandora. Does sound a bit better. I wonder--- Could one use an iPod touch on the Audi Connect wifi and plug IT in direct to AMI for listening to Pandora? Would THAT yield better sound quality since it eliminated Bluetooth?
    J. Patterson
    Alabama
    Jun 06 2016
    Florida
    I have a Panavise phone holder that's next to the vent, so I had the cable exit at the top right corner of the radio.
    I duplicated dropshadow's set up from this thread ====> http://www.audizine.com/forum/showth...ll-phone-mount
    Jun 06 2016
    Florida
    Quote Originally Posted by doug97gxe View Post
    and get this one
    +1
    The top cable is the one I'm using in conjunction with a 3' extension cable (30 pin).
    Jun 18 2009
    Phoenix, AZ
    and get this one
    I already have the 'official apple' extension adapter in that first picture, I used it all the time in my RS4 in combination with the adapter I had in it that replaced the stock satellite radio receiver, worked great.
    So I got this lightning extension cable - https://amzn.com/B01HP6LB2M and it plugs into that lightning to 30 pin adapter, which plugs into the MMI adapter :) It works, so I'm happy. Charges my phone and I can listen to audio coming off of it at the same time which is what I was after. Thanks dudes.
    2017 Camaro SS 1LE
    Active Member Two Rings boolias's Avatar
    Dec 16 2015
    Santa Cruz, CA
    If you have an iPhone 6 and up beware of the Audi lightning cable. I have not been able to get it to work with my iPhone 6. It connects and starts to charge and play, then 20 seconds later it disconnects. Works fine with a 6th Gen iPod touch though.
    Jun 24 2008
    Encino, CA
    SiriusXM sound quality is much better when streaming from the app vs using the satellite signal
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by boolias View Post
    I have a 6S and a 5S and the ones above work perfectly
    Present:
    Dec 16 2015
    Santa Cruz, CA
    Yes, the 30 pin adapter and cable perfectly. I have both the lightning cable and the 30 pin cable w/ adapter and it is disappointing that the lightning cable doesn't work.
