Audi a4 (b5) 2000
Good afternoon everyone.
For family reasons, I have to purchase a full size van.
Car was purchased from elderly lady in Fort Lauderdale, and it was used as summer vehicle for last 5-7 years, when she was arriving from Connecticut to Florida during winter.
Technical condition - almost perfect.
Exterior - vehicle has paint issues.
Technically - vehicle fully serviced and well maintained.
What I've done:
- Timing belt kit (The parts for european cars - VAG, Contitech, HEPU, SKF, INA)
(all belts, water pump with metal impeller, rollers, tensioner and seals. Next timing belt change on 120-130.000 miles. KIT is covered by lifetime warranty. Which means, the store will send you new timing belt kit for free, when you send them the existing one)
- Engine and transmission mounts (Corteco - OEM supplier.)
- Valve cover gasket (VAG);
- Spark plugs (NGK);
- Ignition coils (Beru);
- All filters (Cabin, air, oil, fuel, transmission) (Mann and k&n);
- All fluids:
Engine oil (every 3k miles 0w40 mobil),
Transmission fluid (pentosin),
Brake fluid (pentosin),
Coolant (VAG).
Differential oil (Fuchs);
- Brand new brake kits, including brake pads and rotors (Power stop k528);
- Front and rear brake caliper repair kits installed. (new seals, rubber guides VAG);
- Outer and inner tie rods ends with tie rod boots. (TRW);
- Brand new set of wheels (8v0601025s) with Continental tires. Factory balanced. (3k miles on them);
- Coolant extension tank (VAG);
- Coolant thermostat (VAG);
- Brake fluid reservoir (VAG);
- Brand new starter. (Bosch);
- Transmission maintenance with new gasket, filter and oil (Pentosin, Mann);
- Front outer CV boot sets (VAG);
- Cleaned and maintained almost everything.
Total spends, around $7k above the car.
Issues:
- Drivers power window doesn't work. Need to repair window regulator. (Don't have time to change it. Common problem. The part already purchased and lying in the trunk);
- arm rest. Cracked leather;
- minor scratch on the driver seat.
As you see, i was preparing this car for myself, but we all have to make decisions, according to life situations.
Car doesn't require any investments except gas.
Just sit and go.
I've already done everything for you. :)
Do not hesitate to contact me.
P.S.
With the vehicle, I also give away:
- original set of Speedline wheels (r16) 4a0601025 with original tires, which was installed on the factory in 2000.
- Some parts, which I didn't install yet, like strut mounts, driver window regulator, upper arm bushings, oil filters and etc.
- Bunch of gaskets and seals.
- Brand new front brake kit Power Stop (k528)
Price includes R17 wheels.
4500$ - with standart r16 speedline
List Date: 7/21/2016
For more info, click here to view the original listing: Audi a4 (b5) 2000
This item is no longer available.
