Results 1 to 17 of 17
    May 30 2016
    Lake Forest, CA
    Brake noise due to 1 time use and an adhesive backing?
    Dropped my car off today. Had some noise in the HUD and noisy brakes. HUD was fixed. There is a TSB out on it.
    Brakes - I'm told that since the previous dealership that I bought it from may have took them apart most likely to inspect them (they can tell that they've been taken apart,) that the brakes are a 1 time use and have a 1 time use adhesive and that's why they are noisy. Brakes won't be covered under warranty.
    Here's the thing - If I buy new pads with the special adhesive, there is no guarantee that the noise will go away because Audi specifies that a brake job consists of replacing the rotors as well!
    What do you guys think?
    Current:
    2016 RS7 - Nardo Grey - APR Stage 2 - TCU Tune
    2015 Cayenne S Hybrid
    2015 SQ5
    2013 C63 AMG Coupe
    May 20 2010
    I suggest having the dealership you bought the car from fix the brakes for you. I assume you did not know they were taken apart, and it was not disclosed to you. So I would not think it's your fault, and thus Audi (that dealership specifically) should be taking care of that for you, especially for the price of that car.
    May 30 2016
    Lake Forest, CA
    I bought it from a Maserati dealership in Denver.... had it shipped to CA.
    Current:
    2015 SQ5
    2013 C63 AMG Coupe
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Hey so a couple of things. It seems to me that everyone S6, S7 and RS7 complain about squeaky brakes on factory pads. Mine bug the crap out of me and have squeaked from when I bought the car with 30 miles on it.
    2nd thing. I notice a weird humming noise from the inside plastic piece on my HUD when I go over certain roads. Was that the same issue you had?
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    May 30 2016
    Lake Forest, CA
    thats the exact noise that i have on my hud. There is a TSB out on it. They replace the frame of the hud, add a foam insert, and then underneath the car, they add something to better dampen any vibrations or sounds. you should take your car in to get that fixed. mine was driving me crazy.
    Current:
    2015 SQ5
    2013 C63 AMG Coupe
    May 30 2016
    Lake Forest, CA
    apparently because they are the brembo floating brakes, the only fix is new pads and rotors!
    Current:
    2015 SQ5
    2013 C63 AMG Coupe
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by janthony6 View Post
    Perfect thanks!! Yeah it drives me crazy too
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    mike ward mas in denver? if so I may have test driven your rs7
    Jul 27 2013
    Australia
    New pads fixed mine. No new rotors needed
    May 30 2016
    Lake Forest, CA
    yes mike ward in denver....
    - - - Updated - - -
    where did you get your new pads from?
    Current:
    2015 SQ5
    2013 C63 AMG Coupe
    Mar 26 2010
    US
    BMW M3 Competition X-drive
    Feb 26 2010
    Los Angeles, CA, USA
    Quote Originally Posted by Djpeaksd View Post
    DJ...anyway u can record the noise?
    I have some type of vibration/resonant kind of noise with certain kind of road. Hard to pinpoint where...but I think it maybe coming from the HUD or the B&O front center speaker grill.
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by chucky0731 View Post
    So I definitely can however it only happens on certain roads. Next time it comes up for you just put your hand in the hud and there is a plastic piece closest to you and once you touch it the noise goes away. So if it doesn't go away for you then you have something else going on.
    Veteran Member Three Rings Packy's Avatar
    Dec 12 2011
    2009 Audi A4, 66 Corvair Corsa Turbo (future project car).
    Arizona
    Hud was fixed? WAY cool. They "applied" the TSB on mine twice and looked at it 4 times, still rattles. It's the piece that goes across the back of the clear cover. It's to thin. When it vibrates I can lightly lay my finger on it and it stops. I fixed the center speaker grill my self by putting silicone on the clips, for those who had that problem.
    Never had a problem with the brakes except they dust like a SOB!
    2013 S6, 2009 A4,
    May 30 2016
    Lake Forest, CA
    Mine was "fixed" but they said any noise is just regular car noise. I disagree after driving home. I still hear it. It's just quieter. They installed some foam piece and said they did something under the car. Whatever. Still makes sounds.
    Dec 12 2011
    Arizona
    An $80k car shouldn't have rattles, buzzes, squeeks or vibrations.
    2013 S6, 2009 A4,
    Feb 26 2010
    Great suggestion...Thx DJ
