Results 1 to 11 of 11
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Need quick advice. Engine overheating
    Just had a stop driving and check coolant engine overheat while driving to work. Parked car and got a ride.
    Is it safe to drive in 90 degree OUTSIDE temps if I watch the engine temp? Would I even be able to make it very far (dealer ship 1hr away!)
    James
    2019 SQ5, 2021 Q7
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    Probably not. My tstat went in the summer and I had to drive about 5 minutes to the dealer. Barely made it there with the heat on full blast.
    Senior Member Two Rings mjames's Avatar
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    It's your thermostat, it is a common issue. You will need it towed to dealer. Been there, sorry.
    Feb 17 2008
    Ashland, KY
    Figured that. Had good luck with my 2011. This is my first issues after 82k miles. Not bad. The tow will cost $450
    2019 SQ5, 2021 Q7
    Senior Member Two Rings sittinlow's Avatar
    Apr 08 2009
    Long Island
    I remember once in my BMW, I was able to get a tow to the closest dealer from my house when my car broke down. Might want to check if yours does that.
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    FWIW you can buy the t-stat for like $100 or so and just bring it to a capable indy shop or DIY it if you feel up to it. It's not hard, just some steps.
    Search AZ, there are one or two good DIYs and one shortcut that saves a little time vs the "book" way of doing it.
    From what I've heard the dealer gets around $1k to do the job so you may even save a little if you take it to a local shop and show them the diy with shortcut. I've not done it but it doesn't look terribly hard.
    Good luck
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    I had a stage 2 pulley installed on the supercharger while it was off, saved a few bucks on the install and didn't feel so bad about having to replace the t-stat.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Feb 17 2008
    Ashland, KY
    The only good indy shops are still about 1.5hrs. I may try that.
    I do a lot of maintenance myself but looking at the diy...idk if I can trust myself. Almost ripped my hair out changing spark plugs lol
    Apr 20 2014
    dfw
    I did spark plugs. Not too bad. Didn't even want to attempt tstat. 6 hrs of labor per dealer for $50 part. 1k @ Indy garage. No help from aoa. Sorry I just had this issue less than 2 wks ago
    Feb 17 2008
    Ashland, KY
    Quick final update. Dealer took about 3-4 hours to fix. It was the thermostat. total cost was $900 with part. Tow was.... $410!
    All works well and I am happy. Audi of Lexington is one of the most accommodating and friendliest dealers I have been to.
    2019 SQ5, 2021 Q7
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by jamesj2k View Post
    had this issue today actually... AAA covered my tow, and going to a Indy shop so hoping its less than $700
    glad to hear it seems easy and straight forward
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
