Results 1 to 10 of 10
    Established Member Two Rings Adamwagg's Avatar
    Jul 10 2016
    Bournemouth uk
    Crankshaft breather pipe
    Hi guys found today that my breather pipe has snapped and disappeared Ive order a new one. I have never changed one before is there a right way and wrong way and easy way thanks
    Sent from my E5823 using Tapatalk
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    It's pretty straight forward dude. Pull the clip out, put a new pipe in with o-ring, put clip back in. Tadaa.
    Audi Club Bay Area
    Jul 10 2016
    Bournemouth uk
    Cheers mate I didn't get an O ring with the pipe what's the easiest why to get to it from underneath or up top does the clip pull off.. It's made a right mess of my block 😢
    Dec 19 2013
    Make sure you use an o-ring. It should have came in a pipe kit but if your old one is still in there you can clean it up and use it.
    Put a flat head screw driver and pry the clip out. You can see the clip in the pic.
    When I did mine , I had the intake manifold off so it was easy :)
    Audi Club Bay Area
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    +1, I had the intake manifold off as well. For the price of a manifold gasket it made sense to me to just pull everything out of the way and seat it correctly etc. Plus the added insurance I wasn't going to snap off some other brittle piece of breather tubing in the process.
    Dec 19 2011
    Colorado Springs
    I'd replace it for the 034 kit.
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Jul 10 2016
    Bournemouth uk
    Quote Originally Posted by B6A4Dave View Post
    What's the 034 kit
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    034 motorsports. there is an early version and a late version. the split is in 2003-2004 I believe. someone correct me if I'm wrong.
    Great kit. been performing flawlessly for me. easy install with intake manifold off. gives you a chance to replace some of those gaskets along with injector cups (which are a pain to remove-special tool highly recommended) and o rings. 1-2 hour job if you know what you're doing.
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    I went in under the manifold by way of the thermostat, which I was replacing anyway. The hardest part was getting the spring clip out.
    I also used the 034 Motorsports kit for the late-AMB engine.
    Sent from the 7th Galaxy.
    Jul 10 2016
    Bournemouth uk
    I'll be having a go later so I'll let you guys know how I get on 😁
