Hello-
I'm new to this forum but not to cars/forums in general. We recently picked up an 05 a6 3.2. 82k miles and in incredible condition. I knowingly inherited a few common issues (price reflected it). The typical g201 Brake Pressure sensor - Inplausible signal, and 01316 - abs control module read trouble codes - intermittent.
This is causing the obnoxious beeping and abs/esp/emergency brake warning lights.
So:
I replaced the brake switch last night (with oe part from the dealer). All three warnings disappeared immediately. I drove the car twice, once for about 15 miles, the other was a short jaunt. The third time I drove it, the warnings returned.
I have read more about the switch and now understand that the switch breaks internally when installed. My method of installation was to (with the vehicle off) remove the old switch, insert and twist/lock in position the replacement, and then plug in the harness. I did not depress the pedal, first start the car and depress pedal, pull back the pedal, or anything, simply insert, twist, plug in.
Was this procedure incorrect? I'm seeing mixed information online. I would guess that the ABS module needs rebuilding, or the pressure sensor itself is faulty, however the fact that the codes cleared with the initial switch installation makes me wonder if I simply ruined a very sensitive part and it's worth trying another, or if it's just more likely that I need to proceed to the ABS module rebuild.
Thank you!
