Results 1 to 12 of 12
    Aug 15 2015
    Cincinnati, Oh
    DSG failure....?
    So, today, some friends and I decided to install my H&R sport springs. Jacked the car up using the pinch welds, and put the front on jack stands. I can see now why a local shop quoted me 900. Took 3.5 hours for the first front wheel. Anyways..got the 2nd wheels done. Put the wheels back on, and started the car to back it out and turn it around to do the rears. Put the car in reverse, and it popped up and said transmission malfunction, put car in P or it will roll. Went to first, and it just free reved...while making a whining sound. Put the car in neutral, and no sound. Put it in park, and it grinded a bit. Tried again, free reved, then went into park, and the car just rolled...Pulled the codes, and one was for vehicle speed sensor. Is it even remotely possible to fuck up a spring install? I had never done and audi, but a friend has done many. I don't want to believe its related. Car was also just flashed to APR stage 1 2 weeks ago. Car has 1,000 miles left of warranty. What should i do here?
    2013 Phantom Black Pearl S4 prem + DSG. APR stage 1, CTS intake, AWE touring exhaust. Rohana RF2's 20x10, H&R sports
    Nov 20 2014
    New York
    Flash it back to stock and make sure it is your original file that was on your ecu and get it to the dealer if you still have warranty. I think that's the best course of action
    Apr 14 2016
    Austin Texas
    If your shop quoted you 900 they suck and find a new shop.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by chet.rowles View Post
    Actually when I called around to everyone and their mom, all of the spring install prices were crazy high like $600-900 in labor...les Schwab was by far the cheapest at like $200, but they only install parts bought from them so they get you on prices by almost doubling them. They were still the cheapest at like $750 with parts, labor, alignment and sales tax.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Not sure how replacing springs turns into a transmission issue but you said speed sensor fault. Is it possible you unplugged the speed sensor at the front wheel and did not plug it back in. Or damaged the wire while installing the springs?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Apr 14 2016
    Austin Texas
    Oh. Well, didn't know that included alignment, still too much though. $750 with parts would have been perfectly reasonable if that included the springs.
    Apr 14 2016
    Austin Texas
    But I digress. Attributing the dsg problem to this is unlikely unless some weird little sensor thing
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by cspcrx View Post
    This - ignore the other useless posts
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Aug 15 2015
    Cincinnati, Oh
    It ended up being the axle. Which was already notated at audi, but they couldn't replicate it. We did not undo them, which others have not as well when doing springs. Drivers side spline popped out and broke. My dealership is being awesome though, and covering everything under warranty, so..all is well!
    Jan 04 2013
    Phoenix, az
    So the axle slipped out of the hub? Amazing it can drop that much with the arms and sway bar still connected.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Glad to hear, I had that same problem when I hit the curb. It popped out and the only thing was a grinding noise.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Doesn't take much sometimes. My 1st though was damaged/unplugged speed sensor or your axle popped out, but though you would probably see fluid leaking. Glad it's being taken care of! Never done axles on an S4, but lots of Jettas and Passats.
