Results 1 to 13 of 13
    Jun 25 2015
    California Hawthorne
    positive crank case pressure ? HELP
    Can some one tell me why air blows out of the valve cover when I remove the oil filler cap ?I've replaced the pcv valve it's house one the y pipe and the two Cheack valves under the manifold and vacuum lines
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Your always going to have some positive crank pressure. It's just how much you have can be the issue. Are you burning they oil?
    Jun 25 2015
    No major oil leak it seems like way too much air coming out 😕
    Oct 10 2013
    State College PA
    The pancake value opens under vacuum and sucks all the shit gasses out of the crankcase to reburn them. It's called a positive crankcase ventilation bc you will always have some pressure built up. I wouldn't worry too much about it.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Internal engine components seal well, but not perfectly. I'm sure it is just fine.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jun 25 2015
    I shure this is the reason my valve cover is pissing out oil I've replaced the valve cover, pancake valve, it's housing and two Cheack Valves
    Veteran Member Three Rings kwnk's Avatar
    May 21 2011
    '03 SV650S, '76 280z
    Quote Originally Posted by Davdraco1 View Post
    I've noticed when I open the cap after running the engine to operating temp I can see oil burning/smoke. Possibly the pcv or one of the checkvalves are not functioning correctly?
    1999 1.8TQM Avant | H&R Coilovers | 034 1bar tune | 16" URS4 Fuchs | Forge 008 | Borla
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by LongBeach View Post
    Where exactly is it leaking oil ftom? You're certain it's the valve cover and not the cam tensioner gasket?
    In your original post you said you replaced the pcv valve but above you state that the Pressure Relief Valve (pancake valve) was replaced. Have you replaced both or did you only replace the PRV?
    Are we talking about a 1.8t?
    Sent from my LG-H815 using Tapatalk
    Jun 25 2015
    Yea 1.8t awm the pcv valve under the manifold inside of the T is that not also called the pancake valve ?
    Jun 25 2015
    I also replaced both the valve cover and the tensionsioner gasket
    Nov 03 2014
    Missouri, US
    Did you use 5w40 or 0w40 oil?
    Nov 03 2014
    Missouri, US
    Torque spec for valve cover and VVT actuator are both 10 Nm (7ft lbs). I always use grey permatex in the corners of the valve cover seal before putting the gasket on and I've never had any issues.
    Jun 25 2015
    @kruftindustries 1040 at the momento might just re do the valve cover
