Results 1 to 10 of 10
    Account Terminated Four Rings
    Jan 15 2016
    '08 A4 2.0 Avant 6MT S-Line Ti
    SoCal 626
    Arrow RNS-E Navigation head unit and Climate Control
    $400 shipped
    This was pulled from a wrecked 2008 B7 RS4, you will need to retrieve the activation code yourself(google). Everything is still attached to the center console frame and will need to be removed prior to installing into your own car. Top row buttons are not included (ie: hazard switch, coin tray, esp button, sport button)
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    by chance do you have the gps antenna that goes to rnse?
    Jan 15 2016
    SoCal 626
    I don't, sorry.
    Established Member Two Rings boston s4's Avatar
    Apr 20 2016
    a6 avant, s4 cab, allroad, LandCruisers - when audis dont work
    boston ma
    Few quick questions. Does it have the nav disc / map data in drive. Does it have blue tooth?
    Thanks
    Apr 20 2016
    boston ma
    Activation code Audi rns plus
    Jan 15 2016
    SoCal 626
    No idea if the navi disc is in the drive or about Bluetooth, already stated in the original listing that the code is not included. However, a simple google search would indicate that it is easy enough to retrieve.
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    You can get the code from Audi USA. The Bluetooth module is a separate item, it is not built into the unit.
    Jan 15 2016
    SoCal 626
    @kittrell thanks for the info!
    Jul 14 2009
    Pasadena
    id take the CC module if u separate
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Jan 15 2016
    SoCal 626
    Price drop $400
