Results 1 to 22 of 22
    Nov 25 2014
    FBSW Airbag Harness - HELP
    So, I'm a bit stuck and could use some help. I have what was billed as an R8 flat bottom steering wheel which was supposedly plug and play with the RS4. See pics below...
    Recently I went through the install and everything went swimmingly until I got to plugging the new airbag harness back in to the steering column connector and I realized that the new harness plug (the big yellow one) did not fit. So off it all came. Now I'm at a bit of a loss as the stock RS4 harness does not look like the new harness which came on the R8 wheel, so I can't just swap it out. Is there a plug and play harness available somewhere that will fit the new airbag? For others that have gone through this, what other options do I have here?
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Mar 11 2008
    B7RS4 & e46Ms
    IIRC we usually run an A8 airbag with flatbottom wheels in the B7s.
    FRRG AZ Ring
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Subscribed.. I might be in your shoes soon! Do you have a close up pic of the connector from the steering column?
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Oct 12 2008
    NW Washington
    Pm Alex@europrice he might be able to help you out?
    Dec 28 2011
    2007 RS4, 2008 Q7, 2005 4Runner V8, 2001 Impreza RS
    Upstate NY
    It's pretty easy to make that harness fit, here are the details on how I did it.
    '07 RS4 Avus w/ Silver Interior | RS4 Registry
    Senior Member Two Rings Malv1's Avatar
    Nov 23 2012
    1995 Volvo 850 T-5 R
    Rochester Hills, MI
    Quote Originally Posted by AussieDan View Post
    Your pics are not in the link anymore, do you have them still?
    Nov 25 2014
    Thanks AussieDan - I'll give that a shot if I can't come up with another solution by this weekend.
    Dec 28 2011
    Upstate NY
    Quote Originally Posted by Malv1 View Post
    Weird, they're public images on dropbox and should be working fine. Anyway, I threw them up on another server:
    This is the factory RS4 connector:
    This is the newer connector on the FBSW harness:
    The ears marked in red are wider than the ones on the RS4 connector, they just need to be trimmed off with an exacto and the connector will plug in.
    Follow the instructions from the other thread to move the horn and MFSW wires so they match the RS4 pinout:
    OK, here's the procedure to rewire the harness for the TT MKII MFSW. The harness has part # 8J0 971 589 B.
    MAKE SURE TO DISCONNECT THE BATTERY BEFORE DOING ANY WORK WITH THE AIRBAG!
    The 12 pin plug connector (yellow) on the TT MKII harness needs to have three of its wires re-assigned. Open the cover on the back of the harness plug. Looking at the plug connector from behind as if you were going to plug it in, there are 2 rows of slots, which we will number
    1-2-3-4-5-6
    7-8-9-10-11-12
    3 through 6 are for the airbag - DO NOT TOUCH!
    7 = Brown
    8 = Yellow (horn)
    9 = Purple
    10 = Red
    1, 2, 11, 12 are empty.
    Push out the purple lock in the harness and then release the appropriate wire to be re-assigned.
    You need to move the following wires:
    move the Brown wire from 7 >to> 1
    move the Yellow wire from 8 >to> 2
    move the Red wire from 10 >to> 8
    All MFSW controls including the horn should now work. You may also need to trim the tabs from the sides of the plug to be able to insert into the S/C ring socket. You'll know what I mean when you see it.
    Nov 23 2012
    Rochester Hills, MI
    There they are! Thanks Dan
    Tappin and Talkin on the iPad
    - 2014 Glut S4 DSG. Stock
    - 2007 Imola RS4. Milltek catless, non resonated exhaust, APR tune, RS5 20" Rotors... SOLD
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    The pins get stuck about halfway out. So you ll need to put a small jewelers screwdriver in where the purple locking tab was and push down and it ll slide out. Took me a while to figure that part out
    Nov 25 2014
    Quote Originally Posted by B7OrangeA4 View Post
    Nice thanks!
    I plan to do this this weekend, so I'll let you all know how it goes.
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Wow, I never realized the R8 wheel could be used AND retain the MFSW control. Thanks for all of the info.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by CoreyRS View Post
    As can TTS FBSW.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Aug 07 2009
    Ca
    Ahhh shoot, I was thinking of the Euro RS4 wheel. Can that be re-pinned?
    Dec 28 2011
    Upstate NY
    No worries!
    Yeah, once you figure out that first pin it's plain sailing :)
    Quote Originally Posted by bbeast View Post
    How'd you make out?
    Yup, it's kind of weird that Audi went to the trouble of making that minor change to the connector and pinout without changing any actual functionality but I guess it makes sense if you're German...
    Quote Originally Posted by james12lucy View Post
    As can TTS FBSW.
    Yup, I'm running the TT-S wheel.
    Afaik the Euro wheel doesn't need any re-pinning. ISTR there is a VCDS setting for the euro wheel (and your dash-mounted s-mode button will no longer work) but don't quote me on that.
    Nov 25 2014
    Well - I wish I could say it was smooth sailing, but it wasn't the case for me. I only had about a half hour to do this. Trimming the tabs was a breeze, but I couldn't for the life of me figure out how to get the pins out. I had what I thought was a tiny screwdriver and I was sticking it everywhere I could think, but those damn things wouldn't budge. How exactly to you "release the barbs on the pins"?
    I figure what I was using wasn't long enough or thin enough to get where it needed. I assume the tool is supposed to go in the little slot above (or below) the pin hole, and this magically releases the little bugger. Anyway, unless I totally have it wrong, it seems I now have to invest in a repinning tool - ugh. To make matters worse, when separating the wires, I used some needle nose pliers since I was having a hard time handling them with the clumsy stumps I call fingers, and I tore the flesh of the insulation on the red wire. The wire itself is fine, but just sucks cause now I have to do a small repair on that too.
    I'm making this out to be way worse than it was - I'm sure it is easy to do, but I was rushed for time and preoccupied with the mountain of crap I had to do that day. Lesson learned (yet again) - don't try to rush through any DIY project - take your time and do it right.
    Mar 11 2008
    B7RS4 & e46Ms
    Yeah, you need either a re-pinning tool or just something small/thin enough to push through the slot in the plug. I modified a little set of tweezers from an old swiss army knife and made my own tool.
    FRRG AZ Ring
    Jul 24 2013
    Bellevue, WA
    Does anyone know what year A8 airbag? I ordered a euro spec fbsw for 07 RS4 but it doesn't come with an airbag? Can I pick up a used airbag on ebay? Something like this?
    http://www.ebay.com/itm/2004-2005-20...ZXhksc&vxp=mtr
    2007 Audi RS4
    2004 Audi Allroad 2.7t
    2007 Yamaha Vino 125
    Apr 15 2016
    Beach Cruiser
    Venice
    Quote Originally Posted by lorengphd View Post
    Not sure, but I am sure that's a screaming deal for an airbag!!
    Veteran Member Three Rings dturn37's Avatar
    Jun 06 2014
    Chicago IL
    That airbag will unfortunately not fit in the RS4 Euro steering wheel. You need part number 4E0880201CT6PS. You will most likely need to get it shipped from overseas. Here is one on ebay airbag http://www.ebay.com/itm/Audi-RS4-B7-...oAAOSwGWNUVg0k
    CAPRISTO EXHAUST, KW V3 COILOVERS, EURO HEADLIGHTS, R8 ALCANTARA STEERING WHEEL.
    Jul 24 2013
    Bellevue, WA
    Quote Originally Posted by dturn37 View Post
    Shoot. I was told by another person that the part number is 8E0880201CT6PS. Do you think that's inaccurate?
    2007 Audi RS4
    Apr 15 2016
    Beach Cruiser
    Venice
    Just saw this..
    http://www.audizine.com/forum/showthread.php?t=688821
    edit: just noticed you posted in that thread. Nevermind!
