Results 1 to 7 of 7
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Front Fender Screw
    Fitting some wider wheels/tires and was going to remove the screw along the edge of the front fender for good measure. I took the screw out and there is a plastic piece that is connected to the fender liner. Do I tuck this behind the tab or just cut it off? Assuming cutting it off would be better.
    This is the screw and plastic piece:
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Apr 05 2016
    Dallas, TX
    I have been thinking of doing the same thing to help reduce rubbing. Does the liner look like it could sag down at all with the screw taken out?
    Jul 20 2012
    It won't sag. That tab holds everything in place. I just wanted to know if people just cut of that plastic piece that flaps after you take the screw out.
    2013 S4
    Oct 20 2008
    Denver
    just pull it off
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by AudiTFSI3o3 View Post
    just pull it off
    This.
    You need a bit of force, but you can still be careful and pull the whole thing out.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Apr 11 2016
    Phoenix, Arizona
    I took mine off so I could stop the rub and haven't had a problem
    21 RS6 Stage 2
    Apr 05 2016
    Dallas, TX
    Trying not to do many "undoable" mods, I tucked it up under the liner without pulling it off. You can tell by the screws it was a definite point of contact with my tires
