Results 1 to 7 of 7
    Dec 26 2015
    Portland, OR
    Help! - cant get the downpipe out!
    I'm hoping that someone can give me some useful advise here. Trying to remove my downpipes to gut the precats. I have the drivers (US) side out, but cannot get the passenger side out past the trans mount (tiptronic). I have dropped the rear of the subframe about 3", and have the car on jackstands about 20" high. From everything I have been able to read online this is the method to use for the tip cars, but it just isn't working for me. I have spent about 5 hours over the last two nights just getting to this point, and I'm a pretty accomplished mechanic. Audi really crammed a lot of stuff into a small space on these cars.
    My shop is pretty well equipped, but I don't have a lift, and I don't think that I can get any more height on the car. I may be able to raise the back a few more inches, but my problem is fitting the cat past that damn trans mount. it's just too tight.
    Is there anyone on here who has done piggies on a tip car that can give me some pointers?
    Mar 08 2015
    2010 GTI, 2018 Beetle Coast
    Carmel, NY
    Spent same amount of time and have MT. Got stuck at the sleeves. They are so seized I gave up. I feel for you. Sorry I am of no help but good luck. I will probably by new sleeves and reattempt.
    Senior Member Two Rings alcatranz518's Avatar
    Jun 10 2014
    Stoneville, NC
    Did you remove the trans mount? If not, support the trans with a jack and a piece of wood then remove the mount. It still will be tight but with a little twisting, pulling, and swearing/ calling it names it should buy you enough space to come out.
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    did you unbolt the heat shield from the axle?
    Senior Member Two Rings Bonz099's Avatar
    Jun 30 2015
    Rockville, MD
    ^ That and the trans mount
    Dec 26 2015
    Portland, OR
    I was able to finally get it out last night. Ended up loosening the front subframe mounts so that it could be tilted a bit further, and raised the back of the car a few inches higher off the ground. After all of that work to remove the pipes, it only took about 15 minutes to gut the pre-cats. I gave up and got the lawn mowed after that. I'll start putting it all back together tonight. What a pain!
    While I was under the car, I discovered that I have a torn CV boot (which must be recent, as I checked those when I did the brakes a few weeks ago), and my front suspension is pretty much shot. Ordered new axle shafts and a complete set of upper and lower control arms, tierods, etc.
    Looks like I will still be working on this thing next week - glad the weather is nice, so I can ride my motorcycle to work!
    Senior Member Three Rings scottkollig's Avatar
    Nov 12 2015
    Delray Beach, FL
    Quote Originally Posted by alcatranz518 View Post
    I had to call mine all sorts of dirty names to get them to finally slide out.
    The most dangerous phrase in your vocabulary is "good enough".
    DTM 08' S4
