Results 1 to 12 of 12
    Jul 10 2016
    Pueblo Of Sandia, New Mexico
    Exclamation HELP installing new Test pipe
    im wondering if anyone has ever used the 034 motorsports test pipe/ hi-flow cat to install a JHM race pipe (test pipe)?
    https://store.034motorsport.com/hard...lications.html
    I think im going to be ordering soon maybe in the next 8 hours.
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    I don't see why it wouldn't work since your test pipe is still hooking up to the stock turbo and stock Downpipe/midpipe just like o34's hfc/tp
    Jul 10 2016
    034 said they dont guarantee a perfect fit with another test pipe that not made by 034.
    also do you have to replace the gaskets with new ones when you install a new test pipe or hi-flow cat on a B8.5?
    In addition is exhaust seal required?
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    No new seals.... Definitely affects "pedal responce"
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    I picked up all new gaskets and nuts from my local dealer for $23.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Jul 10 2016
    so no new seals... just new gaskets and nuts? Im installing JHM race pipe. https://jhmotorsports.com/shop/catal...0t-p-2625.html
    Aug 29 2014
    No new seals should be required. Just the gaskets and the nuts pictured in the 034 hardware kit. You can however get the OEM parts for almost half price at the dealer. You can probably reuse most of the old ones to be honest, but since they are pretty cheap I'd recommend just getting new gaskets/nuts in while you have the chance. They will probably make removing them down the line easier.
    I used the OEM gaskets on my ebay 3in test pipe. No issues there, so I'd imagine you should be fine with the JHM. They are all bolting up to the same turbo after all.
    Jul 10 2016
    Nice ok im planning on getting a APR down pipe when they release it to the public soon or maybe just buy another aftermaket down pipe like AWE, CTS. kinda like the straight piping instead of a cat i just want sound and a clear exhaust flow =). Will i need anything new for reinstalling a Aftermarket down pipe? (i came from owing a 2012 Impala so bare with me)
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    ^^^careful with the CTS DP, I think it's meant to mate up with the CTS HFC which is shorter, so you may have clearance issues. Party Marty bought mine so he may be able to advise on fitment.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by Dez_Nutz_NM313 View Post
    If you're going to buy the APR downpipe you may want to hold off on installing the JHM testpipe. I'm pretty sure the APR DP includes the TP.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Jul 10 2016
    Aww man do you really think APR will include one with the downpipe? because a A3 (FWD) downpipe already cost 750.00 didnt say it includes a test/hi-flo cat. Yet it looks like one piece from turbo to downpipe for a A3 from APR.
    Mar 11 2012
    Audi A5
    Ventura, CA
    APR kit is HFC and downpipe.
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
