Results 1 to 20 of 20
Thread: BOV Leaking?
    Oct 02 2015
    Audi TT Quattro MK1 1.8T, Audi A4 Quattro B6 1.8T, 10th AE Mazda MX5 1.8I, 1986 Honda XL250R
    KY Louisville
    BOV Leaking?
    So I think the reason my car is falling on it's face and misfiring is because the BOV is leaking here?
    http://pasteboard.co/dRg1yiiTS.png
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    You have a BOV.. not a diverter valve.. so it's probably working just fine, which doesn't mean that the car is working just fine.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Oct 02 2015
    KY Louisville
    That's actually considered a Blow off diverter valve.. Not sure if that changes anything.
    Dec 11 2015
    PA
    if you have a Blowoff valve, it should be coming out of the "horn". I would contact forge about a replacement if its leaking out from where that red line is in the picture. I have a stock diverter valve if you need a replacement or something to hold you over until a new one comes.
    Dec 30 2009
    Quote Originally Posted by nsh95 View Post
    Ok. Yeah it's probably fubar, contact the manufacturer as iksnoved25 has mentioned.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Jun 27 2011
    Borked. Get a proper diverter valve.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 02 2015
    KY Louisville
    http://pasteboard.co/dS1nC5CIy.png Picture of my actual system to air out any confusion..
    Oct 02 2015
    KY Louisville
    So I should definitely start by replacing the BODV?
    Jun 27 2011
    Can you rebuild it? If that spot where it's leaking is threaded you can just put some Teflon tape on it and screw it back together. I don't know how those valves are constructed...
    -CP
    2017 Q7 3.0t
    Apr 15 2014
    Ottawa/Gatineau Canada
    2nd
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Oct 02 2015
    KY Louisville
    So I'll start by replacing it then.. Not seeing anything on rebuilding these from a quick sift.. Or any other ideas??
    Aug 06 2014
    Melbourne/Australia
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Does that bottom part where you drew the red line even come apart ? Not sure about BOV but my forge DV only unscrews at the top where the vacuum hose goes.
    I'd get a proper DV as mentioned above.
    Also, you don't want a $20 DV from aliexpress. That's a Chinese knock off website and that DV is likely poorly made and has no quality control.
    Aside from that, do you have a stock turbo and air box ?
    Audi Club Bay Area
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    An OEM 710N (Audi upgraded DV) would be a cheap solution as well.
    2019 SQ5 Prestige
    Jun 27 2011
    710N ftw. Ran mine for 4 years pushing 21psi without a single issue ever.
    -CP
    2017 Q7 3.0t
    Oct 02 2015
    KY Louisville
    Stock turbo and no longer a factory air box no..
    This here : https://www.europaparts.com/diverter...6a145710n.html ?
    Jun 27 2011
    Yup thats the one. Its not sexy, but it has faster actuation response than anything out there aside from a modified Mitsu Evo DV or a $300 Synapse DV. It'll hold anything a stock turbo can put out. I know its not the exciting choice, but it'll get the job done for a long time without you having to think twice about it.
    -CP
    2017 Q7 3.0t
    Apr 01 2007
    houston texas
    $10 less:
    https://www.fcpeuro.com/products/aud...RE8RoCNoHw_wcB
    What airbox are you running? A cone of the MAF will hurt your performance. Like Charles mentioned, the stock airbox isnt the most sexy/exciting option, but its proven to be the most efficient option, as it is a true cold air intake (sealed from the engine bay and draws air from the front grille and fender.
    2019 SQ5 Prestige
    Oct 02 2015
    KY Louisville
    I appreciate it I picked up a local one and gonna throw it on there be updating the results next day or so.
    Oct 02 2015
    KY Louisville
    Swapped it for a stock, problem solved. Thanks folks.
