Results 1 to 12 of 12
Thread: OBD2 torque app
    Senior Member Three Rings Gmoney1147's Avatar
    Dec 09 2014
    Roseville California
    OBD2 torque app
    was curious which adapter you guys are using and what app for iOS for your cars you are using. How accurate are these apps do you guys know?
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Dash Command with ELM adapter. Really cool actually, tells you a bunch of different things.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Dec 09 2014
    Quote Originally Posted by adam044 View Post
    Which elm adapter
    Active Member Two Rings richr1din's Avatar
    Feb 08 2011
    Santa Monica, CA
    I use the PLX Kiwi adapter for andriod.
    Has been a great tool with monitoring fuel trims, temps, etc.
    Sent from my SCH-I545 using Tapatalk
    Feb 08 2011
    Santa Monica, CA
    I just realized you said iOS, my little bro uses the same company's adapter for the iPhone. Works well.
    Oct 31 2014
    NH
    ELM mini I believe is the full name. It's the small blue one, make sure it is the WiFi model. It's about $20 on eBay.
    Apr 24 2016
    California
    I work for VZW so I use the Hum OBD2 module. It does a lot more than read codes, but I also have a VCDS cable for troubleshooting/logging.
    Oct 31 2014
    NH
    Both look the same... But that's the right one.
    Feb 18 2014
    toronto
    Does the vag com have an iPhone app or android available?
    2008 B7 2.0T 6MT QUATTRO S-LINE
    Feb 08 2012
    Dallas, GA
    Quote Originally Posted by jubegnx View Post
    If you have the HEX-NET one, yes. It only works with that cable/dongle, though.
    http://store.ross-tech.com/shop/VCHN_10.html
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    I use the OBDlink LX. Not cheap as the eBay stuff but has low latency
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
