    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Key in on position, no cel?
    I'm having intermittent starting problems, as well as some other electrical issues and I'm wondering if it is related to relay 219 near the ecu. Sometimes my car will just crank and crank but won't start, if I get out and tap on the ecu box a few times eventually it will start. When it's not starting the cel will not illuminate when the key is in the on position, after I tap the box right I know it will start when the light illuminates again. I'm also getting eeprom error codes, 18048 I believe. Any chance it's that relay? Or maybe a failing ecu?
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    It's timing chains, your car is toast.
    JK
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Anyone?
    - - - Updated - - -
    Anyone? Also I get the esp light intermittently as well as a code for the maf sensor
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    My first thought is the relays under the ECU, they're known to be prone to getting wet and becoming intermittent before failing.
    Jul 28 2008
    Everywhere
    Quote Originally Posted by PetrolDave View Post
    This. I believe there is a thread in the RS4 section with the exact same issue. It says which relay to replace and you'll be fine.
