Results 1 to 10 of 10
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    Guess that Rattle time
    Seems like its mainly on jousting bumps, very loud. LCA & bushings were recently replaced.
    https://goo.gl/photos/MEb1KKnHCCsU6wg67
    Sent from my LG-H811 using Tapatalk
    Misfiring 2004 1.8TQ USP, CX Racing FMIC, Hybrid K04, Milltek HFC
    Aug 26 2005
    Sounds like the brake pads are rattling in the calipers. Make sure the anti rattle springs are installed correctly and are properly shaped (not bent out of shape,) to apply pressure to the pads to prevent pad rattle. If the anti rattle springs look wacked, buy new ones.
    Vorsprung durch Technik
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    sounds just like mine! havent had a chance to check them yet in the rear but given that i sometimes hear a pad dragging this might be it.
    Oct 10 2015
    Detroit, MI
    Sounds like the brake pads are rattling in the calipers. Make sure the anti rattle springs are installed correctly and are properly shaped (not bent out of shape,) to apply pressure to the pads to prevent pad rattle. If the anti rattle springs look wacked, but new ones.
    Is it safe to assume I'll probably need pads/rotors from uneven wear?
    Jan 25 2011
    Philly
    not a guarantee - go check em out first.
    Aug 27 2013
    Philly
    To ensure its the brake pads, drive over a bumpy patch of road a few times. Sometimes without pressing the brake and other times without the brake. That will tell you for sure.
    Oct 10 2015
    Detroit, MI
    Quote Originally Posted by SJorge3442 View Post
    Tested out right. Completely quiet if I'm fully applying brakes over bumps! Thanx
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Put this stuff on the back of your brake pads. Used it for years and years. No squeal, no rattle.
    Oct 10 2015
    Detroit, MI
    Must need that cause I think these are the Anti rattle clips
    Aug 26 2005
    Yes that is the anti rattle clip. I also see a gap between the clip and the caliper. The clips need to be replaced in order to fit correctly. They must press on the caliper firmly so that the pads don't rattle in the caliper.
