Results 1 to 40 of 68
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Things that I learned - B8.5 review
    So, I thought I share some of the things I learned since owning this car.
    1. Downshift, brake, turn, accelerate is by far the best feature of this car. It pulls so savagely.
    2. You will lose racing a new mustang GT on a roll.
    3. Brake job is easy. Just remember, there is no TPMS on the passenger side.
    4. VCDS is a must.
    a. I am able to pull my windows down to vent before I get in. It lets the hot Georgia heat buildup out.
    b. I am able to watch movies on a car when I'm stuck in my 2 hour commute traffic hell in Georgia. - You need this then format your mini SD to 32 GB no matter how big your mini sd is. I formatted 32gb on FAT32 my 128 GB SD. It reads all 128 GB of content.
    c. AVI is the only format that I was able to make it work without trying too hard. Any AVI works. MP4 didn't (MMI 3G+)
    d. I love my gear number in the center display.
    e. Lap time: Right windshield washer > at the end > up button starts > down button records > Pushing up button long press resets (I think)
    f. Honestly, that's all I wanted from VCDS. That and rear electronic brake release for when I do my rear brakes.
    g. eBay blue knockoff cable don't work. The Chinese knockoff black 12.12 does, but the software contains a virus/trojan.
    5. Rear brakes are easy to do, but you either have to use VCDS to undo the electronic brakes or unplug and unscrew the module altogether.
    6. HID fog install is a breeze. Here. Make sure you use a better tape. Also, when you mount the ballast on the wall of the first air opening, make sure you sand the paint off, otherwise the paint will come off easily along with your ballast.
    7. Double beeping sound when the car unlocks is annoying.
    8. Within a year, the LED door courteous light design strip will degrade to a very bad shape.
    9. Audi dealership isn't so bad. Take the good like the tire deals, and don't always take the first deal. They always have room, as long as you can bargain with them for perfect 10 score on their survey.
    10. Continental Extreme Contact DWS06 is an amazing tire for this car. 10k on it, still looks new.
    11. most likely the rattle is coming from the top of the steering column cover or your cup holder.
    12. Cut your nails, so you don't scratch up your leather wrapped door handle badly as I did.
    13. The tire pressure is 38 front 36 at the rear. 41psi is for maximum load, meaning you carry full load of passengers, and gears for 19"
    14. If your car has 18" from factory, the top speed is limited lower than if you have 19" wheels.
    15. Don't ever get the OEM tires that came with it again. They don't last, and there are better tires out there for the price.
    16. If you pull back the automatic gear lever, it puts you in S mode, which changes the gear to 6 instead of 7. This took me a bit to realize.
    17. The AMI to USB connectors that work is in Europe. Also, the cheaper ones don't work that well.
    18. If you get the AMI to USB, you can run a 500gb or 1tb hard drive, as long as you format using above method (FAT32).
    19. Yes. There are 5 hole drilled onto the grey plastic underneath your front license plate. Or more depends on the dealership.
    20. The windshield washer warning is super annoying. Also, the windshield reservoir doesn't take the full gallon. There is always some left over.
    21. Everytime you turn your car off, the drive mode resets. It's annoying.
    22. I get 5 to 7 mpg when I'm in Sport Mode.
    23. I get 25 mpg on highway on Comfort Mode.
    24. If the stock brakes squeel, that means you hit the metal warning rods on the OEM metallic brake pads. It won't stop until you change them.
    25. Trunk ceiling has these T hooks. They're for your grocery bags, so you don't smash your eggs on the way home.
    26. Those elongated holes on the side of the trunk liner is for the net.
    27. The battery is in the trunk, underneath the spare tire. Make sure you clean and air your spare tire in good intervals. They will lose air.
    28. The amp is inside the left side of the trunk liner.
    29. Rain-X will save your life.
    30. Briefly lifting off the accelerator pedal helps with the lag on mid to high RPM.
    31. Even in manual mode on your DSG, it'll change the gear on its own so it doesn't blow up if you hit the redline.
    32. Launch Control: Turn off tracking control>Put left foot on brake>Put right foot on accelerator all the way down> life off left foot, and go.
    That's what I have so far. Hoping this helps someone new to the 2014 S4. Also, if you have some more good stuff, post it. I'd love to learn more.
    Thanks,
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Your car double beeps when you unlock it? My 16' doesn't. Nor did the 2017 a4 I just drove for 2 days as a rental, or my wife's 15' Q7.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Senior Member Two Rings jwallace0988's Avatar
    May 16 2016
    None
    Rochester, NY
    Great to know all this! Taking delivery on my 13' ibis on Sunday
    13' S4 - Ice Silver (DSG, B&O, Carbon Inlays, Black/Magma Leather, Sports Diff) - EPL Stg. 1 ECU w/ DSG tune, Roc Euro Intake, DeAutoKey Full LED interior(white), Red (Front floor), LED Exterior lighting (Turn/Reverse). Eurocode poly mounts, Soundakor DELETE!, Xpipe mod, Carista!
    Past: 12' GTI Autobahn, APR Stage 1, CM FX350 w/ flywheel, Magnaflow CB exhaust :: 06' Scion tC: Full Bolt-ons to turbo build at approx. 300 WHP/TQ on 8-10 psi, Konig After-burners, RL Coils, poly mounts etc.
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    My drive mode doesn't reset, it stays in the last setting used....but good tip on 4b, I need to try it.
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    Quote Originally Posted by eightamrock View Post
    that's something applied through vcds
    Sent from my SM-G928W8 using Tapatalk
    Estoril crystal blue,APR Tune ,stainless steel clutch line, Custom Audi ring subs, BFI weighted shift knob, Passport 9500ci stealth install(in mirror),custom 1 off carbon fibre inlay blue trim, ecs kohfllufl luft intake, Stasis challenge mode exhaust, USP stainless steel brake lines, P3 multi gauge, Snow Performance Meth
    Oct 02 2013
    Redstone, CO
    My car makes no sound during unlock. #21 drives me nuts
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    mine doesnt reset either
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Quote Originally Posted by Midnight_Rider View Post
    I'm not sure I know what this is.
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Nov 06 2013
    Australia
    I didn't get the shopping T hooks. I had to buy one from Amazon
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by DBL R View Post
    Quote Originally Posted by xuandatou View Post
    So if you're in dynamic, shut the car off, go to the store, come out, unlock the car and restart it, it will still be in dynamic!? How?
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Senior Member Three Rings noyzcij3's Avatar
    Sep 06 2012
    Philadelphia
    It's a vag-com code that activates the function. I actually found it useful for the times that I accidentally unlocked the car as I walked away. It's almost like a reminder.
    2016 Sepang S4 P+
    6MT | Black Nappa Leather | Tech Package | Carbon Inlays | Sport Diff | Vag Com Mods | Xpel Ultimate | Ecodes | BFI GS2 | Carbon Mirrors | Alu Kreuz | 034 Drivetrain Mount Inserts | Bilstein B16 RideControl | Eurocode Sway Bars and End Links | AWE Resonated Touring Exhaust 90mm | BBS CH-R | Deval Diffuser | Ecode Taillights | ECS Street Shield | 034 Subframe Mount Inserts | Carbon Imports Low Kick Spoiler | Porsche 19Z BBK
    Jan 21 2016
    Quote Originally Posted by BlownOne View Post
    I've discovered this to be related to the key. Each key remembers the last drive mode it used. I keep one in my work bag and one at the house to use when I don't have my bag. It made me nuts for a while until I figured that out.
    Jan 21 2016
    Quote Originally Posted by noyzcij3 View Post
    GTK! I'm going to enable this once I get someone with a vag-com to come help me out.
    Can I buy one one of those?
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Do you also play Pokemon Go while driving?
    Veteran Member Three Rings UltraS4John's Avatar
    Sep 16 2006
    2013 Audi S4
    Northern VA
    Excellent analysis! BTW, we're relatively close since I'm in Fairfax/Vienna.
    2013 Audi S4 - Brilliant Black (Prestige) DSG + IE Stage 1 & STaSIS exhaust
    2013 VW GTI - Carbon Steel Gray Metallic DSG + APR Stage 1 & AWE exhaust
    2018 Audi Q3 - Daytona Gray Pearl DSG
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    if you set S through MIMI it stays that way, it is only when you use gear shift to set it,it resets on start.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Senior Member Two Rings JustPlaneChris's Avatar
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    It will also make your windshield wipers chatter like a mofo, which is super annoying. I still Rain-X the rest of the glass, but I've left it off the windshield. Chatter is reducing as the Rain-X wears off.
    Chris
    2014 S4 - 6MT | Brilliant Black | Black Optic | Carbon inlays | Alcantara | B&O | CR-15 Strut Brace | 034 Intake Hose + K&N
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    The double-beep is enabled via VAGCOM
    As for staying in Dynamic, that's about the ADS. It stays in the last ADS type you set.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Thanks,
    7 - Disable that.
    24 - They can actually squeal even when new. Its just the pads that Audi uses. Its well documented here.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jun 05 2007
    Nashville, TN
    What is the linked file here? What does it do?
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by JustPlaneChris View Post
    rainex fluid if used in washer tank will gum up low level sending unit and give you false low level warning light that will not go away unless sending unit is cleaned.
    Nov 10 2014
    Apex, NC
    B8 - Resets
    B8.5 - Keeps Setting
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 10 2014
    Apex, NC
    4. VCDS is a must.
    you could have done all this with the Carista App
    Present:
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by doug97gxe View Post
    B8 - Resets
    Rodger that! I was so confused lol
    Oct 17 2012
    NoCal
    Yeah, it's been just like that since I bought it.
    I guess its just the default setting for mine
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jan 28 2013
    B8 - Resets
    True for the "Mode" but the transmission doesn't hold the setting you parked with.
    I have a 2013 and the transmission always starts in Drive mode. I've read you can VCDS it so it'll retain that setting or honor what you've set for your Individual setting, but I haven't tried it.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Lamprey View Post
    Oh I have MT only know of the mode
    Sent from my iPhone8s using Tapatalk
    Present:
    Oct 02 2013
    Redstone, CO
    Quote Originally Posted by jygesq View Post
    Nope. I use Individual and no matter what, my car powers up in Comfort and has since the day I bought it almost 3 years ago.
    Apr 05 2016
    Portland, OR
    I walked a Mustang GT last weekend from a roll... (60 to 130 or so)
    Granted I am Stage I but still!
    I drive my car exclusively in sports mode unless I am in traffic and usually get ~19.
    Geoff
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by whiped View Post
    I echo both these points
    Present:
    Jan 28 2013
    That may be true for a 2015, but not on older models (at least without a VagCom mod).
    Apr 05 2016
    Portland, OR
    MMI Remembers that the car is in "Individual" mode for me.
    Every time I get in my car I have to manually put it in "S" mode and turn off traction control. (Might be able to do something with VCDS but, haven't bothered looking)
    Doing it is habitual now and only takes a few seconds.
    Geoff
    Jun 28 2016
    US
    That app allows you to enable VIM? I guess I missed that somewhere.
    Jun 05 2007
    Nashville, TN
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Is the .exe file the OP linked above a way to enable VIM without VAGCOM?
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by rtmeikle View Post
    No, it is used to format an SD card.
    You can enable VIM via Carista I believe.
    Geoff
    Nov 10 2014
    Apex, NC
    You have the Carista app?
    Present:
    Apr 05 2016
    Portland, OR
    I have Carista and VCDS, I can confirm it in an hour or so if you would like.
    Geoff
    Nov 10 2014
    Apex, NC
    I was asking swank because he was trashing it in that Carista thread I was curious if he actually bought the product
    Present:
    Jun 05 2007
    Nashville, TN
    Oh ok. No, I have Carista, and you can't enable VIM with it. That's the one thing I wish I could do with it but can't.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Rain X will also eventually cause the black windshield trim to spot. You can restore it back with mineral spirits.
