Ok folks, I think I've exhausted the search function on this one...Hoping some of the heavy hitters here have some thoughts or insights.
S4 avant 6 speed. 140k on the clock. Bone stock, no aftermarket electronics.
First, an obligatory VCDS scan.
Saturday,24,June,2017,22:15:55:49885
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06711
Shop #: WSC 87119
VCID: 34669B4004F9B2E13D-5140
4 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1
P1131 - 35-10 - Internal Resistance too High - Intermittent
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
18011 - Internal Control Module
P1603 - 35-10 - Failed Self-Test - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
VCID: 3560A6440F83ABE90A-5140
2 Faults Found:
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
VCID: 2D508E24E7D3E32972-2592
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 2002
Coding: 00306
Shop #: WSC 00254
VCID: 3A7AB578269D4491E7-519A
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 08701
VCID: 2B54803CD9C7ED196C-5140
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
VCID: 408EC79040411E41A9-4EB2
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
VCID: 60CE2710E0817E4189-4B66
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
VCID: 65C03604FFA31B697A-517C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 63351
VCID: 24466B00B4192261AD-4B00
End-------------------------(Elapsed Time: 04:25)--------------------------
www.Ross-Tech.com
Coding: 06711
Shop #: WSC 87119
4 Faults Found:
Coding: 04395
Shop #: WSC 06435
2 Faults Found:
Coding: 00160
Shop #: WSC 63351
Coding: 00306
Shop #: WSC 00254
Coding: 02264
Shop #: WSC 08701
1 Fault Found:
Coding: 16140
Shop #: WSC 63351
2 Faults Found:
35-00 - -
Coding: 00102
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Coding: 00110
Shop #: WSC 63351
Recent work--this problem predates all of these repairs
- New timing belt, water pump
- New Ignition switch
- New fuel pump
- New spark plugs
- New crank position sensor
- New battery
- Not new, but I do have a spare M box ECU that I've been using (more to follow on this)
The issue:
While driving, at random times, my car stalls. Sometimes it bucks right back, but most of the time not. I can go weeks without a peep, or it can happen multiple times in a matter of minutes. When it stalls, I get a beeping sound from the instrument cluster, and then I get a telltale clicking noise from the throttle body, fuel pump relay, possibly other parts. The clicking keeps going as long as the key is turned on. If the clicking is there, the car will not start back up (engine cranks, but no start). My VCDS cannot 'see' the ECU as long as there is clicking.
If the fuel pump relay is unplugged, the clicking ceases. Also, once the relay is removed, the VCDS can scan the ECU.
I can override the fuel pump relay, either by jumping the leads, or manually, and the fuel pump does prime even with the clicking. BUT, the car still doesn't start even when forcing the relay 'on'. This tells me there's gas, but no spark. I have not yet confirmed this--because 'unfortunately', the car is working fine right now. (is the a VCDS code for faulty ignition switch or spark plugs?)
My issue is JUST like this
And this:
Both videos ended up diagnosing the problem as a loose grounding bolt behind the coolant reservoir
And as described in the following threads
#1--unresolved thread
#2--loose grounding bolt behind coolant reservoir
There's more, but you get the point. All signs from the above point to a bad sensor ground, possibly caused by a bad physical ground.
I've inspected and my physical grounds all seem to be completely fine. Have not checked continuity on all ground wires just yet--but the problem is intermittent. If I pull, tug and jostle the ground wires, nothing happens. Additionally, I cannot reproduce the issue if I manually disconnect the ground while the engine is running (yes, the engine shuts off, and yes, there is clicking for a time, but then it goes away--it does not click continuously like it does when its acting up on me). Also, I've pulled on the wires in the ECU wiring harness to no effect.
Possible Clues:
- The car can stay like this for weeks at a time, then randomly be fine one day (it can also drive fine for weeks at a time as well)
- The ECU gets very hot very quickly when this issue is occurring (bad ground?)
- This is not universally true, but it seems to get worse when its raining out. I got caught out twice in the crazy downpours we had in Houston last spring.
- If I swap the ECU, the car starts right back up every. single. time. Now, it might only last me 5 minutes (or 5 days)...it's a mystery. I once stalled out 3 times on the way home from work, one time literally on a railroad crossing (also in the midst of a flash flood). Thankfully, I got it started immediately!
- Sometimes, when the clicking is occurring, the fuel pump will not run. Even if I jump the relay, it will not run. But others, the fuel pump will run, but still, the engine will not ignite
- Under normal circumstances, the fuel pump seems only to prime randomly (see related thread I started)
- When the clicking is occurring, VCDS cannot communicate with the ECU. However, if I unplug the fuel pump relay, it can. The above scan was done with the FPR unplugged.
- There was a critter living on my old fuel pump for some time. This led to replacement of the fuel pump, which ran fine, but had corroded connections that my mechanic suspected caused shorts (possibly damaging other wires/parts in the process). He had to run some new wires to power the fuel pump.
- One time, when going to swap my ECU, when taking the ECU box cover off, it got caught on the ECU wiring, and when I pulled on the cover/wiring, that made the click go away. I cannot reproduce the issue, even if I pull like mad at the ECU
- I have not yet checked to see if I'm getting spark
Really appreciate you reading this far and hope you can shed some light!
