Results 1 to 4 of 4
    Jan 14 2013
    2011 S4, 2013 Q5
    Oregon
    VCDS-Lite on 2010 A4?
    Hi all,
    I just bought a 2010 Ibis White A4 to replace my tiring 2001 B5 S4 and have a quick question concerning VCDS lite:
    I'm able to establish and SAVE the connection under VCDS Lite (Com Port 3), but when I go to scan the engine I receive a message "interface not found."
    I am using VCDS Lite.
    I just want to scan for any potential codes since it's a new car and I know nothing about it yet. Any ideas on what I can do to get it to properly scan? I've used this exact cable (blue Ebay) on my S4 for both scanning and reflashing, so I know it works. Ideas?
    Current Garage
    2018 Q7 3.0T Prestige
    2011 S4, APR Stage II
    Oct 12 2007
    Sacramento, CA
    The VCDS lite does not have CAN network capabilities (which is needed for your car) , http://www.ross-tech.com/vcds-lite/
    Jan 14 2013
    2011 S4, 2013 Q5
    Oregon
    Ah. Ok. I was a little quick in posting my first message.
    I also downloaded VCDS (not the lite version) and was not able to connect through any of the ports when testing, which means I was not able to scan. I updated drivers on the USB, for which I was prompted upon installation, but still no luck. Ross-tech says I'm running the right software for the car... Any suggestions with running the 15.7.4 version of the software and having these issues?
    Current Garage
    Jun 23 2013
    PacNW
    do you have a genuine ross-tech HEX+CAN USB adapter, or just a generic adapter?
    Generic adapter with VCDS-Lite worked on some of the older model Audi/VW.
    For B8 you need the genuine ross-tech cable. The software is free but only works with a genuine cable.
