Results 1 to 3 of 3
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    SOLD 2001 Audi A6 4.2 /w S6 Engine and 6MT - 6750obo
    SOLD SOLD
    Will be moving soon and unfortunately I do not have the room to keep this baby around. So she needs to go to a good home. A lot of time, money, and work has gone into this and is near to being a brand new car for 15 years old. Fires right up, sharp throttle response, and comfortable. Loved driving it so far. Some more details to follow.
    Contact me at [email protected]
    Engine:
    S6 engine
    Timing belt, water pump, thermostat, and all rollers done using factory parts
    Changed all oil seals – no leaks
    Full synthetic 5w40 oil change
    New starter and alternator
    New Power Steering Pump
    New battery
    New fuel filter
    New Coolant Expansion Tank
    Powder Coated Valve Covers – Wrinkle Black
    Drivetrain:
    Audi 01E 6 speed manual trans
    New inner and outer front axle boots
    All trans and diff fluids changed using factory fluids
    JHM short throw shifter
    RS4 clutch with AWE lightened flywheel
    Brakes:
    Full new set Zimmerman rotors all around with new pads.
    Exhaust:
    New Magnaflow downpipes on both banks
    Custom cat-back exhaust system made from magnaflow center muffler and resonated tips
    New upstream o2 sensor on passenger side.
    Suspension:
    All control arms in the front including inner/outer tie rod ends and end links
    Hotchkis front and rear Sway bars
    ST Coilovers
    4 wheel alignment with corner weighting and balancing
    Wheels and Tires:
    “Fat Fives” rims with no bends and perfect balancing.
    Continental Sport Contact 2’s all around no bubbles and lots of tread left (estimated 5/32 or 6/32).
    Interior:
    Full cleaning and detail of all interior trim, carpet, and seats
    Had instrument cluster display repaired.
    Exterior:
    Full 3 stage detail – wash, claybar, polish, and wax
    The bad:
    Just needs the plastic trim piece to hold in the sideview mirror switch in center console
    Some paint imperfections, such as rock chips etc.
    Dent in passenger side rear quarter behind the wheel arch from before I first bought it.
    A/C needs to be charged. Had a faulty safety switch that has been replaced.
    Inspection is needed. As I don’t have the time at the moment. The car just needs to be driven more. So far no check engine light is present, and just needs to set readiness on the catalyst and o2 sensor modules. All others have passed and are ready. When I do drive it to work, its currently only a mile commute, so not enough time/cycle to help this.
    [URL=http://s195.photobucket.com/user/mguerra81/media/Audi%20A6%20Sale/Audi%20A6%2021_zpse5s1psd5.jpg.html][/URL
    Last edited by littleredwagen; 08-11-2016 at 02:16 PM. Reason: forgot asking price
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Three Rings vlangs's Avatar
    Nov 09 2013
    Manhattan
    GLWS! Great looking car
    what are you asking for it?
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by vlangs View Post
    6750obo
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
