Results 1 to 12 of 12
    Established Member Two Rings TallGuy's Avatar
    Aug 06 2015
    California
    Acceleration Stall 2016 Audi A6 3
    I was going down the on-ramp to the freeway and decided to see how the car would perform if I pushed the accelerator to the floor. I felt like I was on the Millenium Falcon out of Star Wars when they first attempted to go into hyperdrive. The car just felt like it was going to stall. It did not feel like a lag. My car has 2500 miles on it, an I drive it very conservatively in Dynamic mode. I backed off the accelerator and the car seemed to have normal power for whatever gear it was in. Does the computer learn my behavior? So I hit the accelerator, and the computer goes WTF what does the driver really want. The engine had been running for 10 minutes when this happened. Do not think this is a dirty part issue. What should I expect for a full out to the floor acceleration from a rolling start. A fly by wire pause, or instantaneous acceleration. Thanks for your input.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by TallGuy View Post
    Not really sure where to start given your long list of questions, but sounds like perhaps the transmission was trying to figure out what gear to be in, and that you didn't give it time to make its choice.
    Also not sure what your expectations are, or even which engine you have (2.0T, 3.0T or TDi)?
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by zcd2.7t View Post
    This sounds like exactly what it was. Gearbox takes a while to figure out what you're trying to do. Any time I really want to mash it, I have to be in manual mode or have been driving pretty aggressively in S for a while.
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Aug 06 2015
    California
    Quote Originally Posted by Sauci View Post
    It is a 3.0, I will test out the gearbox idea. I will try the S mode as well. How long should gearbox take to figure things out 1-2 seconds? Thanks
    Jan 19 2010
    MI/CA
    ...How long should gearbox take to figure things out 1-2 seconds? Thanks
    Since the engine and transmission are both "adaptive", they react to your recent driving style. If you've been feather-footing it and suddenly start driving aggressively, the car will begin to adjust its responses accordingly, but you may not feel the difference until many minutes have elapsed and you've been up and down through the gears several times.
    Mar 26 2010
    US
    It's a feature of the DSG, this happened a lot on my B8 S4, one time in a intersection. Typically happens after slowing down for a right turn, then getting on the throttle - listen to the engine rev freely.. I don't expect the ZF 8HP would have this problem.
    2019 RS5 Sportback
    Mar 11 2012
    Audi A5
    Ventura, CA
    Essentially the tranny is expecting to shift at 2500 or whatever it normally shifts at so its in the process of shifting when the ecu is like "oh shit, he really wants to go. We need to be back in first" and that bogging down is the tranny beginning to shift then realizing it doesn't.
    Jan 19 2010
    MI/CA
    Quote Originally Posted by wwhan View Post
    ... I don't expect the ZF 8HP would have this problem.
    The OP's car is a 3.0T, so it has the ZF 8HP, not the DSG...
    Aug 06 2015
    California
    Plan to take car for a long drive on Friday. Will see what happens. Is there an easy, benign way to have the computer start over (light footed driving).
    I find it troubling to think there would be a safety issue to need to accelerate quickly and have the car stall out. I am accustomed to mashing my foot on an accelerator and have instantaneous response.
    Mar 26 2010
    US
    Yeah the A6 3.0T has the ZF 8HP planetary transmission, which should not be having this problem, unless it has faulty programming. It should not need the same setup time as the DGS, when shifting into the opposite mode (down shift instread of upshift).
    2019 RS5 Sportback
    Jan 19 2010
    MI/CA
    Plan to take car for a long drive on Friday. Will see what happens. Is there an easy, benign way to have the computer start over (light footed driving)...Thanks for your input.
    Just drive aggressively for a several minutes and the computer will figure out what you're trying to do. Also keep in mind that this transmission has eight gears to choose from so the programming has lots of options (gear + throttle position + speed).
    Aug 06 2015
    California
    Thanks I will try that.
