Results 1 to 9 of 9
    May 22 2012
    FAIRBANKS/AK/USA
    Removing old gas from tank
    I have a 1/3 tank of 2 year old gasoline in my tank and would like to remove it.
    I searched the forum and found a section on how to jumper the fuel pump without turning the engine over, but the details were lacking a bit.
    Can someone explain this or elaborate a bit better.
    Where do I do this? At the fuse panel at the drivers door?
    How do I make the connection to my jumper wires?
    What node on the fuse connection do I connect the hot lead to - left or right?
    2002 A4 3.0 MT
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Add seafoam, add more good gas, drive it nice until you need to fill up again...
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    My car sat for 3 years and it started right up. I took it over to the gas station and added the highest octane I could (94) and drove the hell out of it and then filled it up again. No issues at all.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    May 22 2012
    FAIRBANKS/AK/USA
    Not taking any chances, thanks guys. Too many bad past experiences.
    For anyone else out there interested, here is what I found and im wondering which would be easier. Option 1 or 2. I have them labeled. If I do option 1 how do I jumper the relay?
    [IMG][/IMG]
    2002 A4 3.0 MT
    Dec 30 2009
    Too many bad experiences? Why are you letting cars sit for years that many times??
    2 would be easier, as far as removing panels and all, but just turning the key to the on position will turn on the fuel pump, which is even easier.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Turning the key to on only runs the pump about 2 seconds for it to prime and then it will not run again until you crank the engine over.
    Here's how to jumper the relay. When you unplug the relay you will see 6 blade sockets. 2 on top, 2 in the middle and 2 on the bottom. Power comes in from the large middle horizontal blade socket. Turn the key on. Run a jumper from the horizontal socket to large vertical blade socket in the same row. This should apply power directly to the fuel pump.
    May 22 2012
    FAIRBANKS/AK/USA
    thanks for the input Old Guy.
    and thanks for not asking pointless questions like others.
    2002 A4 3.0 MT
    May 22 2012
    FAIRBANKS/AK/USA
    Thanks Old guy, worked well.
    2002 A4 3.0 MT
    Dec 30 2009
    Quote Originally Posted by A4alaska View Post
    Thanks for providing pointless details. Glad you can contribute to the forum as much as you have.
    2001.5 S4 Sedan
    2018 Q5 2.0t
