Results 1 to 7 of 7
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Rear O2 sensor part number 2015 S3?
    Does anyone have this rear 02 sensor part number? I want to swap it out to see if my issue goes away. There are a ton of different ones on ebay, I don't feel like paying $200 to do a test.
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    What's your issue David? The sensor part number is 06K906262AC.
    Feb 11 2015
    New Jersey
    I think I May have it solved.
    Long story short, had a spacer with the stock ECU JB1 box and kept on getting a lean code.
    Since then I updated to Eurodyne stage-2, I left the spacer in and was getting the code much more quickly, within 20-miles. Eurodyne told me to take off the spacer, just did that yesterday and ran all day and this morning on way to work with no code (hoping that was the issue).
    Feb 11 2014
    Anaheim, CA
    If it's the code that indicates too lean, it would be the spacer being too restrictive.
    Feb 11 2015
    New Jersey
    it was P2270
    Faulty HO2S12
    - Lean Air/Fuel Ratio- Check fuel system
    - HO2S12 harness is open or shorted
    - Blocked converter
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Glad to hear you solved the problem.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Feb 11 2015
    New Jersey
    Hopefully fingers crossed
