Sorry if I didn't search hard enough...
Since my B7 got totaled, I resorted to upping the timeline on getting my C5 going. Just completed changing the timing belt, water pump, thermostat, cam seals, half moons and gaskets (with sealant applied in correct places), valve cover gaskets (with sealant applied in correctly places) front crank seal (with new bolt), serepentine belt, JHM EFK install, coolant flush. Engine started up immediately and was running pretty smoothly. Couple codes for EGTs and an O2 sensor, but I'm not concerned with those.
However, after parking it for the night, noticed some oil had leaked. It is coming from the passenger side, directly underneath the oil pan. I did not notice any oil leaking from the rear, front, or driver's side of the pan--just passenger side. But I can't tell where's coming from, since the upper part of the oil pan (where it connects to the block) looks clean and free of any fresh oil.
HALP!
