I've been getting a rushing sound coming from my engine. It doesn't happen when the car is cool, only when it has warmed up and seems to get louder the warmer the engine is. The engine almost sounds almost like a giant fan and loses the ‘throaty’ sound. If I get up to speed it used to goes away by 30 mph or so and the engine sounds returned to normal sound but it doesn;t seem to do that any more.
There no squealing or ticking or dentist drill sounds (bad turbos). I guess the closest similar sound could be a window A/C unit. There are no fans continuing to run after I shut the engine off. The engine seems to run at a normal temperature and performance doesn’t really change at all. i just did an oil change and it didn’t make any difference. The temperature doesn’t jump up if I stop either.
the fan by the oil dip stick turns when the engine is running but the one to the left (passenger side) does not. There is also a fan in front of the radiators that does not turn when the engine is running. I think one would be for the A/C but I don’t know what the other is or if that could be the cause of the change is sound. (also my a/c doesn't seem to be running) I bought this car with 177k miles on it back in December and have been trying to slowly nurse it back to health.
Thanks for any help you guys can offer.
