Hello, I'm having some trouble making proper power in the 1.8t AWM.
I'm using eurodyne to tune, I've smoothed the throttle pedal and done a few other things here and there but as I tinker, test and measure I'm finding the more boost I get into, the lower my AFR's are getting, the car is running a tad rich at idle (sounds like my old honda civic to be honest, gurgling in the exhaust pipe slightly and on decel) and running a tad, well more than a tad rich on my last offramp run. Don't get me wrong, I'd rather be washing my cylinder walls than stretching out my pretty ARP head bolts but what do I need to do here?
log is of idle, rolling start from first to 4th WOT.
Here is the log: Log
At first I was only looking at the EGT shown in measuring blocks and assumed my fuel pump was on its way out though now I'm leaning towards my fuel pressure regulator. 02 sensor was replaced about 300mi before this log. another note, not sure if it's been hot out or what but 5deg timing pull in this log is the most I've ever seen out of this setup.
I'm running:
Bosch 550cc injectors
Frankenturbo f21l
IE 81.5mm 8.5:1 pistons
scat h-beam rods
Stock fueling system
93 octane no ethanol
