Hey everyone, been a while
I know there are a bunch of these threads, and mine might just be a bad coolant temp sensor. But since I have an O2 sensor code figured I'd run it by the experts so I don't waste too much time/resources. So here is the issue:
For the last few months I've had a progressive difficult to start issue ('02 A4 3.0 manual trans). The car will crank but won't start until 12-20 cranks. Has a rough idle for the first 30 seconds to minute then it runs just fine. Lots of smoke and unburnt fuel initially and sometimes revs to 3k RPM for the first minute unless I put it in a higher gear to put a load on it. I do hear the fuel pump whine with key to on position and after the first couple of minutes it will run flawlessly. No CEL but I finally got around to scanning it and got 17585 code, "bank 2 lambda correction downstream of catalyst: control limit attained"
For what its worth, I have JHM tune and JHM downpipes with relocated HFCs. Houston requires inspection with emissions, so I probably have to replace the O2 sensors anyway. But I wanted to see if it makes sense if having a bad "post cat" O2 sensor (which is really still upstream of the cat b/c of relocated high flow cats) would cause such a start up problem. I've also sent a message to JHM to make sure my O2 sensor code and failed readiness isn't normal with their tune and downpipes (I don't think it would be), in which case it wouldn't be contributing to my starting issue, but would be something I still need to figure out.
Thanks for any insight
