    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Painted belt line over fishscale
    So recently i got over a tough time with my b5 that you guys helped me through. To sorta get out of my slumping hate and joy cycles with the car i thought itd be a good idea to freshen it up a bit. I went and installed a white led interior light kit and i painted the belt line molding. I did mine a little differently. I scuffed and sanded the moldings not to the aluminum though. When i painted over them you can see the fish scale texture in it. I think it came out really nice.
    Next too come are some polished aluminum mirror housings!
    Veteran Member Four Rings rockbeau25's Avatar
    Dec 06 2014
    B5 A4 Avant, 4L Q7 TDI, Van Diemen RF99
    WI
    I like it a lot
    B5 A4 Avant
    4L Q7 TDI
    Van Diemen RF99
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    different.. i might let u paint mine :P
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    I like it. Looks really nice Did you take the center console apart to remove the clips for the big trim piece or did you just carefully pry it off? I have been thinking recently about doing my trim in CF, debating if I should pull the center console out to remove the metal clips the "correct" way.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I used the pry method. Beware though you will bend it out of shape and have to bend it back. I practically destroyed my original molding. I used the moldings off a parts car i had already disassembled and painted those. The dash parts are hard to do to be honest or at least a pain. The door trim was a 0 out of 10 unscrew nuts and put the new trim on. Real easy. Ill see if i can get a better texture shot. A lot of people acetone the fishscale off and get a nice piano flat finish. Mine looks like there is a weave under it.
