Hey Everyone,
I was recently throwing a code for an intermittent fan control module fault, screenshot here:
I ended up picking up the new revision of the FCM from ebay here (vs. spending $350 at ECS):
http://www.ebay.com/itm/331880579041
The Issue:
The radiator fan (driver's side fan) is running and spinning correctly, however the passenger side (A/C fan) does not spin at all. Some of the colors of the wiring were a bit mismatched, so we tried to match things as best as we could via the orientation of the wiring.
The differences in terms of the wiring between the OEM FCM vs. Ebay FCM is as follows:
Wiring Differences:
OEM FCM:
Yellow/Green - rad
Orange/Purple - A/C
Ebay FCM:
Yellow/Black - rad
Red/Purple - A/C
At this point, the issues could potentially be the following:
1. FCM Wiring Incorrect for Passenger A/C Fan
2. Actual Passenger A/C Fan Not WorKing Properly (burnt up)
I am fairly certain the Passenger A/C fan was working correctly before the FCM replacement. This is because my A/C now is not getting as cold as it did a week prior (was ice cold last week, now it is just cool). In addition, to add to to the troubleshooting process, it appears that my intermittent FCM has not come back in over 24 hours now. So, it appears that the code at least has been resolved.
Question:
Does anyone have any experience with using this similar Chinese fan control module? And if so, can someone give some troubleshooting ideas on what might be the root-cause of this potential wiring issue?
Thanks,
Asif
