Alright so I bought the carista app they've been talking about recently. This isn't a review, but I do have to start taking care of these issues.
An OBD2 Scanner didn't show any faults, No CEL but after buying carista and scanning it I got 18 fault codes.
The most important being these....
Engine
Part #: 4F1910559E
Coding: 01050109190F0120 (hex)
Component: 3.2l V6 FSI
Fault codes:
P1931 Coolant (FC) fan control module (J293), malfunction
P0456 Evaporative (EVAP) Emission Control System, Small Leak Detected (very small leak)
Airbags
Part #: 4F0910655F
Coding: 13878 (decimal)
Component: 66 AIRBAG AUDI8R
Fault codes:
01317 Control Module in Instrument Cluster (J285)
Sound system
Part #: 4F0910223A
Coding: 26 (decimal)
Component: DSP-High C6
Fault codes:
00877 Treble Speaker Rear Left (R16)
THIS ONE MUST BE STORED, A FEW DAYS AGO I GOT NEW TIRES AND HAD TO STORE THE AIR PRESSURES, THEN IT WENT AWAY.
Tire pressure monitor
Part #: 4F0910273B
Coding: 62221 (decimal)
Component: Reifendruck 3
Fault codes:
02214 Tire Pressure Warning
Heater & air conditioning
Part #: 4F0910043
Coding: 524326 (decimal)
Component: KLIMABETAETIGUNG
Fault codes:
01853 Left Front Heated Seat (Z45)
Driver's door
Part #: 4F0910793E
Coding: 51947 (decimal)
Component: TSG FA
Fault codes:
02115 Lock Unit for Central Locking
Front passenger's door
Part #: 4F0910793E
Component: TSG BF
[Failed to check fault codes]
Ignition authorization
Part #: 4F0910852
Coding: 15 (decimal)
Component: FBSAUDIC6 ELV
Fault codes:
00191 Passenger's Door Handle Touch Sensor (G416)
00179 Access/Start Authorization Antenna, Drivers Side (R134)
00956 Key 2
00180 Access/Start Authorization Antenna, Passenger Side (R135)
So the control module could explain why I got hot twice after siting in trafic for awhile. If just the emergency fan or maybe it's the A/C fan is running and not the main fan...
There's a stutter or bucking when cruising and absolutely barely on the throttle, just enough to maintain speed. Possibly the evap leak? I was thinking maybe the MAP.
