Results 1 to 4 of 4
    Oct 21 2012
    teaneck
    Will 255/35/20 fit my S4 B8.5
    Hey guys,
    I am looking to get rims and tires with the following spec and want to make sure it fits properly. Any thoughts?
    Section Width: 255 Rim Width: 9
    Aspect Ratio: 35 Offset: 35
    Rim Diameter: 20
    Bolt Pattern: 5x112
    Hub Bore: 66.6
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Yes they will fit, but you will get rubbing on back, was mainly the passenger side rear for me. I had some 255/35/20s conti DWS06, they were great. But down sized to the 19s, got tired of the rubbing on certain spots on my daily drive.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Mar 21 2015
    Theres 85 pages on wheel and tires that's stickied
