Results 1 to 23 of 23
    Established Member Two Rings JordanBetch's Avatar
    Jun 22 2015
    St. Charles, Missouri
    B5 S4 Raceland Coilover Install
    Diving into my Coilover project today on my 01 s4, and have a few questions that my research has left fuzzy. Ive seen people reuse stock bump stops, and people not use them at all... So some input there would be cool. Also have read walkthroughs that say bolts need to be torqued under load and some that say just tighten all the bolts (this seems important). I am also doing the rear shock mounts, but those seem pretty straight forward. Just would like some input on those 2 things before getting the car up. Thanks in advance!!!
    Dec 10 2013
    Borden, Ontario, Canada
    Always torque bolts with the suspension loaded.
    Reuse the old bump stops of the coils don't come with them
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Aug 24 2014
    Newport Beach, CA
    Personally, it's easier to jack the suspension up and torque everything down properly under load. Also, I used an 034 density line upper strut mount and new OEM strut hat along with fresh hardware (all nuts and bolts) to make sure everything was done completely and correctly.
    2024 M3 Comp xDrive
    Jun 22 2015
    I did the rears tonight, drove around a little bit and they settled noticeably. I tightened everything down with the hub jacked up. I do have a question about the upper control arm, when I took it off the shock mount it was tightened down pretty solid with the mount at a 90° angle, should I replace it as tight in the same fashion? Now that I've done it all it wouldn't be hard to adjust that. I just made it tight enough to where it wouldn't come out but could still swing up and down with a little force. Also getting faint creaks but I'm sure that's because they are brand new.
    Dec 10 2013
    You want to tighten the shit outta that. Bushings are made to flex, but they're not doing anything with how you set them up; you're just wearing the shock mount and bushings away in the metal parts
    IG: 24_et
    Sold:
    RIP:
    Jun 22 2015
    Quote Originally Posted by Bordom View Post
    Is there a certain position I should tighten it down in??
    Established Member Two Rings shepa401's Avatar
    Oct 20 2011
    Wisconsin
    Quote Originally Posted by JordanBetch View Post
    There are torque specs to tighten them to. I couldn't get my torque wrench to fit in half the spots when i was doing mine. I just jacked it up and went a 1/4 turn passed good-N-tight.
    I found this for reference when i did mine.
    http://www.audihowto.com/audi-a4-b5-...-1994-to-2001/
    Dec 10 2013
    With the hub jacked up. I usually stop to tighten when the car starts to lift up off the jack stand
    IG: 24_et
    Sold:
    RIP:
    Aug 24 2014
    Newport Beach, CA
    This. Or if you'd like to be more precise, you can set the car down on ground (with the wheels on of course) and measure the distance from your hub to the fender and replicate that by jacking the suspension the same distance prior to torquing everything down.
    2024 M3 Comp xDrive
    Dec 10 2013
    Quote Originally Posted by christianb5s4 View Post
    X2.
    I did this method when I put the coilovers in my S4. I used the other method for my A4, but it worked just as well.
    Don't forget to get an alignment after 2 weeks or so
    IG: 24_et
    Sold:
    RIP:
    Jun 22 2015
    Thank you for the advice guys, it is much appreciated. Any tips for getting this bolt out under these lines? (I know the body plug is supposed to be removed)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    There is no bolt under there? You are doing coils, take three out holding the strut top in
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Senior Member Two Rings joeSfour's Avatar
    Nov 09 2011
    South Bay, CA
    Pictures of the bolts you need to remove are in here:
    http://www.audiforums.com/forum/diy-...l-arms-173205/
    Current - 2001 B5 S4 Imola Avant
    2009 VW GTI
    Past - 2002 B5 S4 - 034 STK 5858 PT fully built 3.0L
    Jun 22 2015
    I am trying to do the front without touching the pinch bolt
    Dec 10 2013
    In that case, those are caps and you pry them out. They will be destroyed in the process and then you have to get new ones
    IG: 24_et
    Sold:
    RIP:
    Jul 07 2009
    Alberta, Canada
    You'll be able to get that bolt with a wobble extension on a socket wrench.
    No need to remove the pinch bolt. Undo the two top bolts and the bottom one on the knuckle then push down on the hub while you slide the whole coilover assembly out.
    Make sure you use the little washer on the correct side of the top mounts as well.
    Jun 22 2015
    I don't want to jinx myself by saying it sounds easier than anticipated, cause I'll run into a roadblock or something I'm sure. I'll be starting on the fronts early Friday morning, and if I have any problems the'll be posted up in here! Thanks again everybody
    Established Member Two Rings m47thew's Avatar
    Feb 03 2016
    2001 Sierra 1500 HD
    Quattroland, Canada
    Sub'd! I may be in for questions as well because my KW's should be arriving soon.
    2001.5 S4 - Milltek SuperDual Exhaust, GIAC Xplus tune, 034 adjustable upper control arms (front and rear), density line lower control arms, front sway bar end links, rear sway bar + reinforcements, KW V3 suspension...
    Jun 22 2015
    Reusing the bump stops on the front... Most people say they cut it, where? And does that stupid sleeve stay??
    Dec 10 2013
    That sleeve is the dust cover. Recommended you keep that. I'm not running them on my Solowerks coilovers though, so it's your choice
    IG: 24_et
    Sold:
    RIP:
    Jun 22 2015
    Kept them on and figured everything out. they're all set 2.75" up from the bottom and it seems every corner sits at a different height... But the 10 miles I've driven on them I'm pleased for now. Interested for everything to settle and get broken in!
    Aug 06 2008
    Canadia
    thats because your binding all your bushings
    Valiant effort but you should stop working on your own car before you kill someone.
    the B5 S4 is like the mafia... there is only one way out!
    Jun 22 2015
    Quote Originally Posted by MacDaddy View Post
    Thank you but what exactly did I do wrong to risk somebody's life?
