Originally Posted by
christianb5s4
You splice into the original passenger side o2 sensor harness (green), I followed this guide as it will be the same for any wideband so the stock ECU can log AFRs. Of course your rear o2s must be coded out to do this, I will take a look at my car in a few hours after my meeting to confirm what wires are used to which pins on the stock connector.
So in ma i csnt have my rear o2s coded out at all. So was thinking how to make it work....
Couldi use a 3 position / pole switch to switch between reading the actual rear o2 sensors data and the widebands o2 data?
I would get a cel while doing logs but with the flick of a switch be able to pass inspection again and get rid of cel??
Or do the o2s legit need to be coded out to log?
