Results 1 to 13 of 13
    Mar 12 2014
    Atlanta
    Different brakes and rotors front and rear?
    Just had service and I need rear brakes and rotors. I've decided on Akebono and ECS slotted rotors. Is it ok to do this while the front remains stock?
    The easy answer is go ahead and replace both but I need tires too so minimizing the expense all at once is an important factor too. Am I better to just go with stock pads and rotors if I don't want to do both now?
    Estoril Blue 2013 S4 / EPL Stage II / EPL TCU Tune / ECS Kohlelaser Luft-Technik Intake / ECS Wheel Spacer Flush Kit / CR-15 Upper Strut Tower Brace / Pioneer Subwoofer Upgrade
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Perfectly fine to me. Think, many of us upgraded to front bbk, which is dramatically different to rear brakes. But be aware your rear wheels is going to be a lot cleaner than your front wheels. I'd suggest you do front brake pads at the same time.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    OEM will probably cost just as much of not more. You will be fine holding off on the front imo
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    For rears, you can almost get Myele rotors for the back and still get Akebono pads all the way around for the cost of just OEM rear rotors. Check out ECS or Rock Auto.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Mar 12 2014
    Atlanta
    Would it be ok to change front pads and not the rotors? Pads are the cheap part
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Just do the rears for now and do the front rotors/pads when you have the cash...replacing everything at once is your best bet brotha
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by sacandagaD View Post
    This too. I went with Meyle rotors and Akebono pads for all four corners from fcpeuro.com. all of it shipped was $404. Totally worth it IMO. Sure, not as pretty as slotted rotors, but just as effective!
    Jul 02 2013
    Quote Originally Posted by cbnat View Post
    Depends on how much is left on the rotors, if they need replacing soon or are lipped/scored, might not be worth it bedding new pads into them. But again, if all you want is OEM or equivalent rotors, there are some alternatives price wise.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Not to hijack the thread I'm in the similar predicament. Rears needs to be replaced and thinking about doing all at the same time. Is Akebono pads with Meyle rotors a better setup than Stoptech rotors and hawk pads? I researched and noticed it was pretty common for the S4. Thx.
    Sep 15 2013
    MD
    Also I'm a daily driver and drive mostly highway.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I don't have an S4, but I just swapped my rotors and pads this past weekend on my A4. I went with Zimmermann rotors, and Akebono ceramics all around and the total cost with the G2 kit to paint my rotors was $392.xx, but I did all of the work myself. For my application, I found that Amazon was cheaper for some parts; while I used ECS for others. 2 day free shipping was the winner, because ECS wanted $35 to ship just the front rotors. Not to mention that I bought my front and rear pads separately from Amazon for $124, but the same set would have cost $180 + shipping from ECS. I chose to do all 4 corners at once, but you would be fine doing both sides on the rear now, and doing the fronts in the future.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 12 2014
    Atlanta
    I'm thinking now of passing on the slotted rotors. This is front and rear.
    Akebono (115.71)and Meyle (109.98) = $225.69
    Akebono (115.71) and ECS slotted (369.90) = $485.61
    Oct 23 2014
    Buffalo, NY
    Slotted rotors look nice, and have functional value when you're really pushing the car, but IMO they aren't that functional on the street. Not to mention that you can open the door to issues later on and/or decreased pad life.
    °2011 A4 | 6MT
