Results 1 to 8 of 8
    May 31 2016
    Mexico
    Question on KW Height Adjustable Springs (HAS)
    I just had KW HAS installed on my 2016 Audi Q5. After the install, the installer gave me my springs back along with these strut covers. Aren't these supposed to be on the Struts or am I missing something?
    Veteran Member Three Rings rusq5's Avatar
    Mar 27 2015
    SF Bay Area
    They are. However, I broke mine from the lows and it was causing a clunking noise. In hindsight, i'd have asked to get them pulled out too.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    May 31 2016
    Mexico
    Quote Originally Posted by rusq5 View Post
    Isn't part of the reason to still have them on to protect the strut from dirt and grim? If so, I would think they should still be on or am I mistaken?
    Mar 27 2015
    SF Bay Area
    Quote Originally Posted by Q5OnTheMove View Post
    Sure. The stock struts are probably short lived on KW HAS though, I'm sure the additional 2.5" of constant compression isn't good for their life.
    -Rusty
    IG: @grn_rs6
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    The foam piece is partially intended to be a bump stop as well.
    Interesting thought but it likely should be trimmed if your lowering heavily. Wonder if it needs to be trimmed for H&Rs.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2018 Audi Q7 3.0T Glacier White/Nougat Brown
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I would've trimmed instead of removing completely, but as mentioned above, your stock dampers are likely to be replaced soon enough anyway, and you can consider trimming and reinstalling at that point. FWIW, on my old Q I went with H&R springs and stock dampers. No trimming required. This time, since I went with shorter dampers as well, some trimming made sense. I believe they removed two nubs up front and one in rear.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    May 31 2016
    Mexico
    I just called KW and they stated they include a new bump stop/dust cover with there Height adjustable springs. I checked my car last night and I saw them on there (there a lot smaller then the stock ones). Just wanted to ensure everything was kosher on the install.
    Now time to get my GIAC stage 1 tune!
    Veteran Member Three Rings mkasperzak's Avatar
    Jan 16 2014
    Transition Patrol Carbon, Transition PBJ, Commencal Furious
    Installing mine Friday, good to know
    2014 SQ5, BBS CH-R, GIAC DP 183 Fluidampr/57 AWE SC(3.18 PR), AWE Touring, Roc-Euro, Bilstein PSS10, 034 HX/X-Brace/RSB/Inserts, Thule Edge/Flow, Kuat Trio
    Build Thread / IG @thebird_sq5
