Results 1 to 17 of 17
    Feb 06 2013
    WV
    2001 ecu compatibility ???s
    I purchased a 2001 avant which needs a lot of work to get her back on the road. It needs the windshield, heater core, and headgasket redone. I have a nice 6758 efr turbo itching to get under the hood so out will come the gt2560r eliminator turbo and in will go the 6758. The flow rate is insanely different between these 2 so it will need a tune which will be maestro since I already have the cable for my 99.5. I opened the ecu box and the ecu has PES 440 wrote on it. If I am right this tune was for t28 based setup which a gt2560r is basically a bb version of a t28.
    I do not want to flash this ecu as I am guessing it is chipped. What I am wanting to know is if I can buy another 2001 ecu and swap it in or do I need the ecu and some other accessories? Thanks
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    I'm pretty sure you have to use a CH box for 01's since they use me7.5. Auto, or manual shouldn't matter as long as you have vag-com to change the soft coding.
    When I got a spare ecu to tune for my 2871r I got an ecu out of an automatic 1.8t Passat, and changed the soft coding. Worked like a champ.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    How do you change the soft coding on the automatic vs manual?
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Vag com. I believe it's in the transmission module, don't remember exactly. Several write ups on it.
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Good luck tearing out the entire dash to replace that heater core. Not a fun/easy job. Sometimes it's better to get a bucket, pump, clr/acid and running it through the old core.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Established Member Two Rings B5Riches's Avatar
    Dec 15 2015
    Bayside, NY NYC
    I have a CH ecu for 01 stock
    Sep 12 2008
    South Central PA
    don't plan on running more than 25psi on your 6758.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Feb 06 2013
    WV
    I might sell it and go gt3071r instead.
    The heater core is leaking on the inside. It's got to be done, yay....
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by Dan[FN]6262 View Post
    I thought you said the newer ones are fine. Unless his is one he's been hoarding awhile(I've seen his sig for over a year about the 6758)
    Sep 12 2008
    South Central PA
    The quality issue has been fixed. But over spinning them can still drop the turbine.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Feb 06 2013
    WV
    I had mine gone over by a company that borg warner suggested. Mine actually came off an indy car and I traded the housings for the regular housing that have the integral bypass valve. I was told to use the speed sensor with it. Indy car started with 6758 and went to 7163. So it's not a newer one but I could find out if it was one of the earlier ones though I was told borg literally trashed all the problematic turbines. I want to run it but the thing is I have a manifold and dp for t3 housing. I can weld but my fab skills suck shit.
    Mine does have the aluminum center housing but all indy turbos did. I also have the multiposition waste gate design.
    I would think a gtx3071r wouldn't be a bad choice. I am wanting 350awhp from it.
    Dan what did you do with the compressor and it housing? Basically the rest of the turbo?
    Sep 12 2008
    South Central PA
    The blown 6758 is laying out in the garage. I've been searching for some place to rebuild it so that I can sell it since I ordered a 7163. No one at Borg Warner will talk to me, just keep getting sent to voicemail.
    If you want 350awhp the 6758 will easily do it, and spool insanely quick.
    GTX3071 spools much slower. I have experience with both. EFR hands down, all day long.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jan 16 2006
    LA CA
    Dan are you going to run the speed sensor this time? If so what setup? I am curios for mine.
    Feb 06 2013
    WV
    I doubt it can be rebuilt since borg warner does not sell parts for them and the technology in the aftermarket is not there to make them. How much would you want for your busted unit as long as 5he comp cover and compressor is usable? I have made some insane turbos over the years and I am sure I could mate the compressor and adapt the cover to another turbo.
    Sep 12 2008
    South Central PA
    Quote Originally Posted by nynoah View Post
    I think the only people that make a sensor is the company Road Rage. Yeah, I am going to pick one up for this turbo.
    Quote Originally Posted by zandrew View Post
    The compressor and housing are fine, no damage. What's it worth to you?
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Feb 06 2013
    WV
    I need to look at its size and do some figuring on compatibility. How hard it would be to swap it too say a gt30 or gt28 turbine. It's a 6mm bore and the gt ball bearing series is 5.99 but it should still work. Or I could bore the comp and mount it to a tried and true stage 3 t3 turbine. There is some Taiwan efr turbo compressors and i thought about trying one of them.
    Give me a price. If you want I can get you the guys info that took care of me but be forewarned, if you get ahold of him and you like talking turbo your going be on the phone for awhile. I will pm you his info.
    Sep 12 2008
    South Central PA
    Actually, I have so much junk laying around that I can set up a jig and make a EFR manifold and downpipe that would bolt up to stock exhaust, so would work with any aftermarket exhaust. I think I'm going to do that.
    If my plans change I will definitely PM you.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
