Results 1 to 11 of 11
Thread: Battery light
    Established Member Two Rings Nilya's Avatar
    Aug 19 2008
    2004 A4 1.8T
    BRAMPTON, CANADA
    Battery light
    Today I installed my dash camera. I removed the positive terminal on the battery. I ran the wire from the cigarette lighter behind the nav, then behind the instrument cluster, up the A pillar to the middle of the windscreen under the rear view mirror. Connected back everything. Now I tried to start the car, it tubles to over and start for 2 second then shut off and the battery lights stays on. Just tried to lock the doors and my remote does not work. Help please. 🙏 Thanks
    Aug 19 2008
    2004 A4 1.8T
    BRAMPTON, CANADA
    At the bottom of the speedometer it also says 301.0 km where I had 256000 and under that it says SAFE.
    Apr 15 2014
    Ottawa/Gatineau Canada
    Yellow bat light in the DIS or the small red batt light ?
    Aug 19 2008
    2004 A4 1.8T
    BRAMPTON, CANADA
    The small red battery.
    Aug 19 2008
    2004 A4 1.8T
    BRAMPTON, CANADA
    I did multiple searches and nothing was working. Someone said to check the cluster. I removed the connectors and connected them back and it works now.
    Apr 15 2014
    Quote Originally Posted by Nilya View Post
    This light denotes a bad alternator.... BTDT.
    http://www.audizine.com/forum/showth...-in-dash-(red)
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    you may be able to get away with just changing the brushes in the alternator, i did that and got by for close to two years before i replaced it with a re-manufactured one...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Aug 19 2008
    2004 A4 1.8T
    BRAMPTON, CANADA
    Thanks all.
    2004 AUDI A4 1.8T
    Jun 27 2011
    Your cluster is in SAFE mode, which means you tripped up the Immobilizer somehow. Not sure how to fix that...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    haha guys he said he fixed it by reseating the connectors
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Could have pulled a wire when running the power cable, causing it to be loose.
