5 speed quarto converted to rear wheel drive, hem center diff included in case you would like to revert
UPDATE: Abs Module to be installed the end of the week, in addition to installing stock cat for SMOG purposes, Test pipe included with sale but the ABS/Brake light and CEL will be cleared. Oil change will also be accomplished Friday (Jul 29th)
CONS: All common to b5 models
CEL on for the test pipe. There is no cat so it pops the CEL, this can be fixed with the non-fouler mod or just leave it as I did.
ABS/brake light on: BOSCH 5.3 ABS modules are notorious for failing due to micro soldering. I have a fully functional rebuilt module in packaging to be included with the car. If I had time I would do it myself it is a very easy swap.
Airbag light on: Once again notorious for b5?s due to the seat either being slid back too far, or someone sitting down to hard, it messes with the airbag connected under the seat. Once again common and very fixable issue. Never botered me.
1999 (99.5) Audi A4 1.8T Quattro (RWD)
141,xxx miles
1.8 turbo
5 speed manual transmission
Converted to rear wheel drive
Exterior silver 7/10- small dent on passenger side wheel well, front bumper has some rock chips
Interior black 7/10- rip in drivers seat bottom and center armrest
Timing belt and water pump done at 125k
Drive belt tensioner replaced by Motoring specialist in Vacaville at 139k
New Toyo extensa HP tires at 137k
Tires rotated July 9th
Sunroof
Black leather seats
Bose sound package
s4 bumpers, skirts etc...
H&R coilovers (brand new wrenches from ECS tuning included.)
GIAC stage 1 tune
TurboSmart BOV
K03S turbo
Drilled/slotted rotors up front
Manzo catless test pipe
VMR v710 18x8.5 squared setup
Apex turbo timer
VDO boost gauge
RS4 grille
034 control arm kit
Silicone turbo inlet pipe
APR silicone throttle body hose
polyurethane snub mount
3 inch magnaflow muffler
depo headlights
6k hid
aluminum shift knob
I'm sure I'm forgetting somethings as well..
clean title
Call/text.. (708) 752 5872
$3000
Motivated seller, willing to negotiate
PICTURES:
